rear wheel spacers
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 79tx4x4, Jan 10, 2001.
  1. 79tx4x4
    79tx4x4 Registered Member
    Dec 9, 2000
    17
    houston
    I heard that I can put spacers at the back wheels that can match the front, do I have to change the wheel studs too? where could I find those spacers and the studs, anything I have to be beware of. thanks
  2. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    Check out the review of these spacers on the main page. No, you don't have to change studs as these spacers have a separate set of studs built into them (as in the spacer is bolted onto the axle with the original studs, then the wheel is bolted onto the spacer via a separate set of studs that are pressed into the spacer themselves). Several people on this board, including myself, are using these with no problems that I have heard of.
  3. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    No problem what so ever, here is a link to get you some.
    http://mccordhouse.freeservers.com
  4. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Will putting the spacers on create more stress on the bearings, seals etc, since the tire will be farther away than stock or does 1.5-2" make that much difference???
  5. Espen88k5
    Espen88k5 1/2 ton status
    Feb 19, 2000
    981
    Norway
    Yes they will put a litle more stress on the bearings but no more than a offset rim will. I have the performance wheels ones that I ordered from the link in the tech section here on CK5. I got them made 1,5 inch wide. IT LOOKS SO MUCH BETTER, I cant belive I waited so long to do this. Becky Jones at Performance wheels was really nice to deal with. Tell them you got the information here at CK5 and give a litle back to this great place...
    <A target="_blank" HREF=http://www.espen88k5.coloradok5.com>http://www.espen88k5.coloradok5.com</A>
  6. 84Blazr
    84Blazr Registered Member
    Nov 29, 2000
    50
    Stillwater, New Jersey
    I got the wheel spacers that they reviewed on CK-5 and they are great! The added stress by the spacers will not be too much to handle unless you go much bigger than 1.5". they are definatley worth it and very simple to put on. Good luck.
    Know any GOOD Wheelin' in Northwest Jersey, let me know?
