rear wheel wobble
Discussion in 'The Garage' started by NEK5, Jul 11, 2006.
  1. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    i had a little wobble in the left rear tire after dirtyjim swapped in his rear end, and i had my buddys dad look at it, and said that it had a little more play in it than the other side, either that or it was a bent rim, well today i swapped on 31s, and checked it again and it still does it...any ideas?
  2. sledheadak
    sledheadak 1/2 ton status GMOTM Winner
    Apr 29, 2005
    1,283
    anchorage,alaska
    bent axle shaft
  3. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    could it be the wheel bearing on that side?
  4. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    btt
  5. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    It could be bearings, bent housing mabey
  6. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    something to worry about?
  7. Chaddy
    May 23, 2005
    4,110
    Salt Lake City,Utah
    I think I would want to address the issue.
  8. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    hmm. i got the rear end from a member hear, and he said it was under warranty
  9. diesel4me
    Jul 24, 2003
    17,546
    936
    Massachussetts
    swap one...
    Can you swap in an axle from your old rear end in it??--its not that hard to do.....I'd fix it,a bent axle might wobble for years,or it might just snap too...why risk it?....:crazy:
  10. blackblazer717
    blackblazer717 1/2 ton status
    Jul 1, 2004
    470
    massachusetts
    i say swap a shaft from your old housing bro.... are they the same spline or did dirty jim put a different center section in with the locker>?
    LUKE
  11. BAJA_BLAZER
    BAJA_BLAZER 1/2 ton status Author
    May 17, 2001
    517
    San Diego, CA
    A bad bearing you would hear and feel, a bent housing won't cause wobble. Assuming this is a semi-floating axle it is most likely a bent axle shaft, bent wheel or improperly seated/mounted wheel.
  12. broncoman6524
    broncoman6524 1/2 ton status
    Oct 31, 2005
    2,469
    chuluota Fl
    not to be an ass but he said that it happened even after he swapped tires and rims. im guessin its the shaft.
  13. DirtyJim
    DirtyJim 1/2 ton status
    May 4, 2005
    665
    San Diego
    could be. his buddy dropped the rear kinda hard when lowering the truck when i took the frame supports out and the wheels were on hand tight.
  14. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    hmm, i am getting this grinding/howling/vibration noise, but its coming from the front(which is getting swapped soon), its almost the same noise the back one made before we swapped it out
  15. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    well found the problem, looks like the axle may have been dropped on that side, looks warped, good thing the 10bolt still in the yard:D
  16. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    how does it come out anyway?:D
