Rear wheels lock up
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by TopOff, Feb 25, 2002.
  1. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    I have a 71 c10 (w/air) converted to 4x4 Truck with a 396 th400/205 d60 ft and 14 FF rear (drums). I cut off the rear brake pressure regulating valve from the FF. I later found this valve is $250.00 at the dealer.... :(
    I have new 1/2 ton Master Cylinder and new 1/2 ton proportioning valve. The rear brakes lock up VERY easily.
    Question. Do I REALLY need the rear brake pressure regulating valve? I am sure others are running without it. What did you do to stop the rears from locking up?
    The only thing I can think of is the 1/2 ton brake MC and prop valve.
    OR
    The Dana 60 has the wrong brake lines and banjo fittings?
    I had these custom made using Teflon braided lines and banjo fittings. I could not find the dana 60 brake banjo/bolts. I am wondering if these tiny holes in the teflon brake lines and banjos are my problem?
    Anyone have thoughts suggestions? I really want to fix this ASAP. Thinking of going to a brake specialist. Or talking to Dynatrac... and buying there D60 parts.
    I also bled the brakes three times, and changed the front pads, thinking they are glazed.
    Roads, where we're going we don't need...roads. - Doc.
    '73 Blazer, 383 - 3/4 ton, ARB F&R, 35"
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    As long as your are getting fluid to the front calipers I wouldn't worry about the size of the brake lines (thye squirt fluid when you bleed them...right?). You don't need much flow just preassure. To keep the rear brakes from locking up I would install a adjustable prop. valve. You can buy them from summit for around $30. Install it after your 1/2 ton prop valve (which is for a disc brake truck...right?) and you will be able to adjust it till the brakes both lock up at the same time.
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
    <a target="_blank" href=http://community.webshots.com/user/triaged>See it Here </a>
  3. TopOff
    Jan 16, 2002
    1,760
    Folsom, ca
    Yeah, I was thinking of an adjustable proportioning valve... The only one I saw was the Wilwood one. It was $94.00. Cheaper than the rear pressure regulating valve.
    Doesn't anyone else have this problem with the 1 ton setup? What was there solution?
