Rear window? and pinion yoke?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ftn96, Feb 7, 2001.
  1. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    #1 does the rear window at full down, still stick up a little out of the gate a little? IF so has anyone else devised a protective guard of some sort that would protect the glass when hauling say plywood or 2x4's???
    #2 I got my rear end completely pulled apart last night. I noticed that the pinion yoke looks to have a pinion seal guard attached to it with what looks to be a weight. Is this thing balanced?? The guard on mine looks a little contorted. Was wondering if I should replace it it or the whole thing depending on its seperability.
    On that note, does anyone have a "GOOD" 10 bolt pinion yoke?
    Will work for beer, parts and tools.
    90 Jimi,350/700R4/241/10bolts/4.10's/33's/4"
    <A target="_blank" HREF=http://www.nashvillek5.freeservers.com>http://www.nashvillek5.freeservers.com</A>
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    #1 my window goes all the way down
    #2 i have no idea sorry
    s.smith 77blazer lookin 4 mud [​IMG]
  3. 1. My window goes all the way down.
    2. I dont think the yolk is balanced,if the yolk has a grove on it where the seal touches it I would buy a new yolk.Mine was like this,when I replaced the seal it still leaked a small amount.If the guard is not rubbing the seal I wouldn't worry about it.
  4. Emmettology 101
    May 9, 2000
    8,126
    FL
    #1 My window usually goes all the way down....
    #2 There is a "shield" on the yoke. If I remember correctly, I think there is some sort of weight on there, but I have swapped or switched them and never marked where the weight was. So far so good.... ;)
    I dont have a spare yoke for a 10 bolt, but the one off a 12 bolt with a big u-joint is the same and you can get a new Yoke from the dealer for around $50-60...
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; <A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A>
  5. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    # 1= both of the ones I have owned sticks up about 1/8". Never tried to make anything to cover it. I had a sheet of plywood in the rear. Now I jus t put it in the trailor......
    C'moe
    <font color=black>the blazer is "Back in Black"
  6. moneypit
    moneypit 1/2 ton status
    Sep 3, 2000
    1,382
    COLORADO
    I have a extra yoke for a 10 bolt. Let me know if you want it.
  7. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    Ok , as far as the pinion yoke. Mine has no grooves or nothing like that. Just saw that weight and saw that one side was a little dented, but it doesn't rub or have any other defects. SO Im assumings its good.
    Now this window thing, I have seen many mixed views here. All the way down, 1 inch, 1/8 inch, etc etc. Mine sticks up little less than an inch, and its slow going up, then a little over half way up it bangs really load and then continues on up. Basically I need to take it apart and operate. But I was just wanting to know if it is supposed to go all the way down.
  8. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    I've worked with military blazers (CUCV M1009 1984-1987) for years and they all stick out, some more than others. The standard fix was to bolt a small piece of angle iron across the tailgate to protect the glass when it's retracted.
  9. rock.monkey
    rock.monkey 1/2 ton status
    Oct 28, 2000
    296
    100 Mile house B.C. Canada
    My window stops 1/2 way up and i have to push it in to get it up the rest of the way. To fix this.. take off the cover on the inside of the tail-gate and pull the crossmember that holds the motor on. Give it a good tug up, so it moves about an inch. It's caused from standing in the center of the gate when open. My window also sticks up a little too
    Bill Innes
    88' Jimmy
    Built for <font color=blue>Function</font color=blue> <font color=red>NOT</font color=red> <font color=blue>Fashion</font color=blue>
