rear window conversion
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by squirelmurphy, Jun 4, 2002.
  1. squirelmurphy
    squirelmurphy Registered Member
    May 17, 2002
    12
    Lakewood, Ca.
    I was thinking of adding a power tailgate. My truck is a '78 with a manual gate. I'm sure somebody has done this, I was just wondering what nightmares lie in store for me if I do it.
    I don't feel like rewiring the whole truck, I just want to be able to roll the window down from the drivers seat.
  2. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    with a relay the guts, or tailgate with the omotor in it already and a switch you could make it easy...
    i dont see why one would want to wire it in as a factory deal. too much work. make it custom and call it better than stock
    grant
  3. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    I did the conversion and it wasn't a nightmare....gutted a gate with all the stuff i needed minus the glass and channel the glass rests in. Your manual tailgate will have all the holes already for the power stuff to bolt into. I also made myt own wiring schematic and now I have a gate operatable from the drivers seat and from the back glass....got the key switch in the back rekeyed to my existing door key for $15...anymore ?'s feel free to PM me!
  4. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    It was all a bolt in deal. The hard part was running the wires up along the frame and punching a hole in the dash for a switch. I converted over when my manual crank broke off and it was not a nightmare at all.
  5. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    Hmmm...so I could do it w/ my '74? Was it a total tailgate swap, or just motor and guts minus glass? The reason I ask is because a guy here at work has a '74 and he swapped the rear out for an electric one. It doesn't seem to line up very well. It looks like it sticks out at the top. I haven't looked at it very much, but I have only been considering this in the recent past.
  6. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    For my '82 is was just a gut swap. You could pull off the inner panel and see if the holes to mount the motor are there. If I remember right (its been awhile), The motor sits on the drivers side of the center latch assembly. Maybe you could look at that guys setup for reference.
  7. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    Thanks for the info.
