REAR WINDOW DOESNT ROLL UP
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TB2Blazer, Jun 2, 2003.
  1. TB2Blazer
    TB2Blazer 1/2 ton status
    Apr 6, 2002
    166
    Cleveland, GA.
    My rear window in my 85 K5 rolls down but won't roll up. I have checked the front switch and fuses. Anyone have any idea whats wrong?
  2. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    there is a cutout switch on one of the latches in the tailgate, i believe it's the drivers side. (it cuts power to the motor if the tailgate latch is open.) check that to see if it's bad. the dealer should have a new one if it is. or you could just cut the wires, and splice them together like i did. just make sure you don't try to roll the window up if the tailgate is open.
  3. mxrcr589
    mxrcr589 1/2 ton status
    Apr 17, 2003
    148
    poop
    i got a 90 jimmy and i can roll my window up or down when my tailgate is down /forums/images/graemlins/k5.gif
  4. BJarvis354
    BJarvis354 Registered Member
    Jun 17, 2002
    58
    New York City
    One thing that happens to me sometimes is the liftgate support cables get caught in my tailgate and will not let that latch close properly. Another thing is that my window got stuck in the up position over the winter, and I had to lude the gears up to get it released. Regulator cable got chewed up too and had to be replaced.
    Brady
  5. JDBlazer454
    JDBlazer454 1/2 ton status
    Feb 27, 2002
    951
    Vancouver, Wa
    I had a similar issue but it was my window regulator on the drivers side (where its been hit) was bent and binding. After straightening and lubing real well it goes up and down pretty easy.
    Here is a good thread that gave me some good ideas on how to fix mine.
  6. 87project
    87project Registered Member
    Jul 9, 2002
    98
    Alabama
    [/ QUOTE ]that was my problem 2 /forums/images/graemlins/thumb.gif
  7. rdwest1369
    rdwest1369 Registered Member
    Jun 2, 2003
    17
    Richardson TX
    Brady
    Ive got the same problem on my 78 Jimmy except the regulator cable needs to be replaced & I cant get to the thing window glass is blocking access Ive tried all kinds of thing to get the window up but its stuck in the down position any suggestions will be appreciated.& Ive been told the cable is no longer available /forums/images/graemlins/confused.gif
    thanks
    RichW
  8. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    my 88 model blazer will roll up & down w/ the tailgate up or down. when mine quit working it was the switch your key goes in. it is made real simple, & was just full of mud. just had to clean the contacts.
  9. rdwest1369
    Jun 2, 2003
    17
    Richardson TX
    I wish it were this simple but I can see the cable hanging off the motor behind the window & I cant raise the window to get to it
  10. Big Red
    Big Red 1/2 ton status
    Jan 9, 2003
    250
    Bristol, CT
    i had this problem a little while ago. first off, check to make sure ur tailgate is actually ligning up properly, if its not, the power ain't gonna get there(ie- the cutoff switch thinks its open) second, try opening the tailgate, pushing the latches on both sides closed and the try everyswitch (on the dash and the tailgate) If neither works, theres suttin else that i can't see would cause the problem. /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif
  11. rdwest1369
    Jun 2, 2003
    17
    Richardson TX
    i had this problem a little while ago. first off, check to make sure ur tailgate is actually ligning up properly, if its not, the power ain't gonna get there(ie- the cutoff switch thinks its open) second, try opening the tailgate, pushing the latches on both sides closed and the try every switch (on the dash and the tailgate) If neither works, theres suttin else that i can't see would cause the problem. /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif
    thanks but like I said the cable to the motor is broken off but I cant move the window high enough to get to it or to replace the motor if I have to
    thx again
    RichW
  12. rick88blaze
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    [/ QUOTE ] i just called the dealer out here and they have it in stock. here's the part # 12542292 it's about $37. as for getting to the motor and all, you just might have to take the window out of the sash to get full access to all of it. if you do, just clean the window and sash really well, and put a few layers of duct tape on the window to get it to fit tightly back into the sash. i did that when i replaced my sash 2 years ago, and it's still holding the window in place.
  13. rdwest1369
    Jun 2, 2003
    17
    Richardson TX
    thanks !!
    great thanks I guess the guy that was suppose to work on it didn' t bother to check thats one of the reasons I No longer go to him. I'll check with the dealer Monday thanks again
    Rich W
