rear WINDOW guys HELP!
Discussion in 'The Garage' started by k5freak44, Apr 17, 2005.
  1. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
    ok my rear window stopped going up, i thot the switch was broken (the one in my dash) but i took it apart and the switch is not the problem, i ran a jumper wire to the ground and to both of the other plugs were the switch went, and the window jerks downward when i touch one side and the window dosent do anything when i do the other... my rear key switch has never worked.
    here is where i need ur help. is this going to be very difficult to fix? everything else in my electrical system works except this.
    is there a fuse or something i could have blown?
    the end of the plug that does nothing when i connect it to the ground looks kinda melted.
    what should i do, where do the wires run.
    thanks.
  2. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    I just went through this with my 88. In the tailgate, on the left(drivers side) latch, INSIDE the gate is a safety switch that won't allow the motor to operate up if the gate is open. I just jumped the blue wires at the switch for now.
  3. k5freak44
    Jun 1, 2004
    2,164
    Plano, TX
    thats exactly what it was and if it wasant for you i woulda torn apart my dash by now. thanks.
  4. protechk5
    protechk5 1/2 ton status
    Sep 26, 2004
    2,015
    VA
    i swear on my 90k5 i dont have that? but my friends 88 does? did some come without them or iam crazy
