Rear Window is Sluggish
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Agar426, Apr 25, 2001.
  1. Agar426
    Agar426 Registered Member
    Apr 16, 2001
    12
    Los Alamos, New Mexico
    The rear window on my '90 Blazer is becoming more and more sluggish as the years go by (for that matter, the two side windows on the doors are suffering from the same fate). When it finally goes, is there a better system out there, more modern motor, more modern regulator, etc? Or am I stuck with repairing the factory stuff? The window was never very efficient to begin with...my parents used to have an '87 full size Bronco, and the back window on that thing went up and down much better (so did the side windows). Is GM's system just simply less efficient? Any help would be appreciated. Thank you.
  2. Agar426
    Apr 16, 2001
    12
    Oops! Wrong Forum! I will repost over on the right forum.
  3. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Ooops you may want to post this in the 73-91 section............
    <A target="_blank" HREF=http://www.burt4x4.coloradok5.com>http://www.burt4x4.coloradok5.com</A>
  4. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    My '69 Caddy's windows are fast. They're like guillotines. The regulators and tracks are lubed on a semi-regular basis... Try lubing everything up.
  5. 72GMCJIMMY
    72GMCJIMMY 1/2 ton status
    Mar 17, 2001
    142
    Steves right, I use silicone spray on the window channels.
