rear window issues.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by personaltrainer, Mar 5, 2005.
  1. personaltrainer
    personaltrainer 1/2 ton status
    Nov 4, 2004
    178
    Atlanta GA
    I replaced the rear window (tailgate) motor b/c my last one just stopped working. Even with the new one the window is VERY slow and stops often. It will not start back until i take my finger off the button and then try again. Anyone else know of this problem? any ideas? thanks.
  2. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    Here's a list of things to check and should keep you busy for a while. :grin:
    Grease the cable that attaches to the motor (inside it)
    Clean and grease the regulator and tracks that the window rides on
    Window guides inside tailgate may need to be replaced/dirty
    Make sure the window guides are in allignment
    Window seal in the hard top may need to be replaced/dirty
    Inner and outer rubber guides in the tailgate that the window rides against may be hard and need to be replaced
    Wires may be corroded internally and need to be replaced
    BTW: do you still have the old motor? If you do could I possibly get it?
  3. personaltrainer
    Nov 4, 2004
    178
    Atlanta GA
    yup, that should keep me busy.
    and if I had the old motor I'd give it to you but - it's gone. Sorry and thanks.
  4. biobry
    biobry Registered Member
    Dec 26, 2003
    76
    North Florida
    Clean/replace the switch/button
    contact resistance as Spearchucker said is most likely the problem if all the mechanical stuff passes muster.
    Bryan
  5. trailblazer86
    trailblazer86 1/2 ton status
    May 16, 2004
    112
    North Shore of Lake Ontario
    Check your voltage at the tail gate, both while running the windo and while not running the window.
    If you notice the window works faster with the engine running, you may want to run larger wires to the gate. The complete harness is not that hard to copy with larger wires.
    Running my window was scary and now I am trying to rig a window independant of the tailgate.
