Rear Window Key switch thingy
Discussion in 'The Garage' started by broncoman6524, Jan 1, 2006.
  1. broncoman6524
    broncoman6524 1/2 ton status
    Oct 31, 2005
    2,469
    chuluota Fl
    Ya i dont know what its called but you stick the key in and turn, the window moves. That thing:D
    mine dont work. does anybody know what this piece is called? I looked through my lmc catalog but i couldnt find anything
    thnx
  2. dyeager535
    26,979
    Did you take the window apart and make sure the wiring is in good shape? Could be bad wiring and not the switch.
    You can also "rebuild" the switch if internally its still in good shape. Mine was just a bit corroded, cleaned the contacts and it worked again.
  3. lamberthkp
    lamberthkp SITFU Premium Member
    Jan 17, 2005
    1,468
    16
    West TN
    maybe mine needs to be cleaned up think that maybe what i do tomorrow.
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    You know what sucks ? On most of our trucks , you have to have a fit trying to get to the screws . I had to unbolt my glass , slide it out , unbolt the mechanism , just to get to the bolts I could see but couldn't get a flexible nutdriver on .
