Rear window key switch
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by CAPTAINK5-CT, Sep 13, 2000.
  1. CAPTAINK5-CT
    CAPTAINK5-CT 1/2 ton status
    Sep 10, 2000
    124
    CT, USA
    I can't get my rear window to roll down with the key (power). It works from the dash switch but not the key. Any suggestions.
  2. Espen88k5
    Espen88k5 1/2 ton status
    Feb 19, 2000
    981
    Norway
    Did a search for old post's about this much discused problem:
    http://www.coloradok5.com/forums/showthreaded.pl?Cat=&Board=blazer4x4&Number=36955&page=&view=&sb=&vc=1#Post36955
    http://www.coloradok5.com/forums/showthreaded.pl?Cat=&Board=blazer4x4&Number=36956&page=&view=&sb=&vc=1#Post36956
    http://www.coloradok5.com/forums/showthreaded.pl?Cat=&Board=blazer4x4&Number=36958&page=&view=&sb=&vc=1#Post36958
    You might have to hit the attatchment, then Back to get the pictures to load.
    This might help you some.
    I used the search words key switch tailgate
    And got plenty of "hits" there is lots more reading for you if you need more, just ask.
    http://www.espen88k5.coloradok5.com
  3. Eagle86K5
    Eagle86K5 1/2 ton status
    Mar 5, 2000
    974
    Whitehouse, Ohio
    I took mine apart and cleaned the contacts, actually I cut an old bulb up and made new contacts, just soldered them over the old ones.Still works fine a year later.Saved the 60.00 for a new switch...
  4. JAllen
    JAllen Registered Member
    Mar 27, 2000
    7
    Utah
    I had the same problem that you did except that my electric door locks wouldn't work either. Come to find out the rear window key switch is on an entirely different circuit than the front rear window switch. With my 91 blazer, the problem turned out to be not the rear window motor or switch but a short in the circuit. Took me a week to find it.
  5. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I have the same problem in mine. From inside, the window rolls up all the way but with the key it has about an inch to go when it stops.
    90K5
