Rear Window - Key?
Discussion in 'The Garage' started by big jimmy 91, Apr 20, 2004.
  1. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    I got my rear window working , except for the key in the gate switch /forums/images/graemlins/confused.gif
    What is the possible problem(s) with it?
    Do I have to remove the whole regulator to get at it?
    Anyone deal with this problem?
  2. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    The inside of the switch may be corroded. There was a post a few yrs ago that showed how to disassemble and clean the key assembly, I'll see if I can dig it up ... hopefully someone bookmarked it.
  3. big jimmy 91
    Feb 21, 2004
    639
    Thanks , it sure is a lot easier to fix something when you get the right info. /forums/images/graemlins/thumb.gif
  4. big jimmy 91
    Feb 21, 2004
    639
    ttt /forums/images/graemlins/eek.gif
  5. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    From within the tailgate, remove the 2 nuts that hold on the key housing(for lack of a better description). Remove the wiring from the back of the key switch, and remove the whole mechanism. The remove the key switch from the housing by a c-clip if i remember correctly, clean those connection pins. Also take the pin contraption out of the switch and clean the connections on the inside of the switch then put it all back together /forums/images/graemlins/thumb.gif
  6. spearchucker
    Nov 17, 2003
    1,556
    Bay area, CA
    /forums/images/graemlins/waytogo.gif
    The post I was looking for has a broken link. Hopefully that description will help.
