rear window motor
Discussion in 'The Garage' started by bowtiewrench, Nov 16, 2004.
  1. bowtiewrench
    bowtiewrench Registered Member
    Oct 19, 2004
    24
    Woburn, Mass
    Does anyone know where I can buy a new or used rear window motor? Mine is stuck shut and I cannot open the tail gate which is a royal pain in the ass. LMC truck parts doesn't have them and I have looked every where else with no luck. Also is there any other things besides the motor that could be causing it not to go down? Thanks
    Alex
  2. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    The dealer will have it.
    Check the wires, plugs, fuse and the switch.
  3. dyeager535
    26,980
    Pop the inspection plate, remove the cable from the motor, and turn it with a drill to lower the window.
    I'm not sure if the safety switch on the passenger side will keep the window from going down, or if it only works to keep the window from going up.
  4. 90v1500
    90v1500 Registered Member
    Oct 1, 2004
    56
    Huntsville, AL
    The safty switch may be the cause of the problem also, and it has to do with the motor, so you can still run it up and down with a drill. The dealer will have any parts you need but make sure they look it up under the right model blazer, (the r1500 doesn't have a power rear window).
  5. bowtiewrench
    Oct 19, 2004
    24
    Woburn, Mass
    Thanks for the input, I will tear this apart as soon as I have the time. Where is this safety switch located?
    Alex
  6. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    IIRC it's on the dr. side tail gate latch /forums/images/graemlins/thumb.gif
