rear window motor
Discussion in 'The Garage' started by adamforsythe, May 30, 2005.
  1. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    Hello,
    I just bought a 1986 K5 Blazer and I noticed that the rear window was kind of slow. Well a few days ago I went to roll the window back up and the window would not go up. It makes a clicking sound. Did I kill my motor? I noticed there was two motors :confused: for the window. One is under the glass and a little black box above the glass that has a cable and a few wires going to it.
    Adam
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    1 of those is the motor(longer blackish colored box) the other is called the transmission(roundish in shape)they are connected together by the cable. If you take the cable off the motor side and connect a drill motor to the cable you can at least get the window back up. Check and lube all the moving parts in there and tighten everything up and see if that helps before you start replacing things.
  3. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    Hey thanks for the help I will see what I can do. I never had a truck with power windows.
    Adam
  4. MudNurI
    MudNurI 1/2 ton status
    Jul 15, 2001
    2,113
    VT
    LOL my 86 has a dead rear window too. I just keep a drill connected to cable, with the tailgate cover off...and when I want it up or down use the drill.....quick/cheap fix LOL
    Brandy
  5. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    Is the motor a junk yard part. Or can I buy it new some where? I can't find one.
    Adam
  6. MudNurI
    Jul 15, 2001
    2,113
    VT
    lmc??
  7. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    The problem with getting one out of a yard is unless you test it on the spot, you go through all the work of pulling it outta the truck and you still don't know whether it's good or not. I'd pull the panel on the tailgate first and make sure that's actually the problem. I thought my window motor died but pulled it apart to find out that the track that supported the window had been bent and jammed itself in the tailgate.
  8. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    another issue is, its not always the motor. There are a lot of moving parts remember. I've heard of guys replacing the cable and the window worked as good as new. I used to take my cover off and grease the workings(slide, arms, etc.) of the window assembly monthly. I'd disconnect the cable from the motor, lithium grease on everything, and run the window up and down a few times. Also the weather stripping in the window slides has an effect on the function too. In my case, my motor was fine, it just had too much resistance to fight.
  9. FastMaxx
    FastMaxx Registered Member
    Apr 26, 2005
    71
    GA
    I hope its the switch that went bad on mine (86 k5). The other day I let it down and it wouldnt go back up. It dont even click when I press ^. It clicks when I press down so I geuss its the switch. BTW it takes about 2 min. to let it down and about twice that to let it up. Its kinda sloooooooooow....
    Could you describe that drill thing a little more? thanks.
  10. jhellwig
    jhellwig 1/2 ton status
    May 7, 2005
    420
    Bonaparte, Ia
    Step 1: Take cable off motor.
    Step 2: Insert into chuck.
    Step 3: Do I need to say it? :D
  11. rpellicer
    rpellicer Registered Member
    Dec 20, 2004
    38
    Susanville, CA
    Can the cables be taken apart to be lubed? Also, can the channels on the side be adjusted? The bottom of the window smacks into the motor on the way up, and I have to push and guide the window so it clear.
  12. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    DAMN IT.
    Well I took the panel ogg and hooked my drill up to the cable. I got the window up. Then for the hell of it I rolled the window back down and then it went UP. So I think I fixed it. But now my tailgate will not come down. If it's not one thing it's the other.
    Adam
  13. xrmperformance
    xrmperformance Newbie
    Jun 6, 2005
    michigan
    cable & trans
    I have a nice one off a low mileage truck for sale as well as tons of other parts. I had drems of rebuilding my k-5 some day so I bought a few @ auctions and took off all the good parts now I'm not sure if I can afford to even keep the truck and I want all the parts to be used before I have to give up the storage area and junk all the parts LMK if you need anything
    Jeff
    xrmperformance@gmail.com
  14. MudNurI
    Jul 15, 2001
    2,113
    VT
    If your windows up the tailgate wont go down. (but I bet its not down when your trying it RIGHT?)
    Leave the drill in the back you'll need it LOL (I bought a cheap one just for my window)
