rear window motor
Discussion in 'The Garage' started by turbofire, Sep 7, 2006.
  1. turbofire
    turbofire Registered Member
    Sep 7, 2006
    13
    nc
    hay guys looking for a rear window motor for my 87 blazer. Have to use the drill right now and its a pain to crawel back there being a 220 5'9" guy. Would like a used one or can u tell me were to find a new one cant find any were that has it.
    thanks greg
  2. BadBob
    BadBob 1/2 ton status
    Aug 14, 2005
    158
    Lyndon, KS
    Classic Parts of America has it.
    part# 11-309 it's $100
  3. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Geez, you got me all excited. I've been looking all over for a window motor for my tailgate on the 76. Sure enough, that part number is 78-91 :mad:
  4. BadBob
    Aug 14, 2005
    158
    Lyndon, KS
    You might be able to find a reman one for pre-78 from Cardone
  5. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    I am pretty sure the window motors are all the same for any rear gate window on a blazer.
  6. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    I'm looking for broken/non-working rear window motors. If you're going to toss it then would it be possible for me to take it off your hands?
  7. Desert Rat
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    That is what I am hoping. My motor I have now works, but I think I have wiring issues. Knowing how hard they are to find, I want a new one to swap in and keep the old one as a backup.
  8. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    I have a good used motor i'll sell you. I'll take $50.00 plus the ride. I did some searching myself last night and they are about $100.00 new plus a $25.00 core charge. PM me if you want it.
  9. diesel4me
    Jul 24, 2003
    17,547
    937
    Massachussetts
    a thought...
    We used to swap power window motors onto others all the time at the junkyard..often the motor itself is the same,but the gear case is different--and its not a difficult job to drill or grind a few rivets out and swap a motor off some other application onto it,and use nuts and bolts to fasten them in place of the rivets..we would use a cars rear window motor on the front door this way,etc...:crazy:
  10. badmix
    badmix 1/2 ton status
    Nov 7, 2004
    4,205
    60
    West Virginia
    I think ive asked this previously, but how hard is it to convert from power rear window to Manual? Can all the parts be had from LMC? Are they jus drop in and exchange parts? Ive taken the panel off and have no idea what im looking at or how it all works.
    Jus curious. Thanks
    Sorry, for being off topic and hi jacking. :D
  11. Desert Rat
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Be very careful messing around in there. I read a story on another K5 site where a guy snipped the end of a finger off when he started removing stuff to do the convert. The regulator is under tremendous spring pressure and slams shut like a giant pair of hedge shears. Somebody here posted a how to that showed how you have to use a C-clamp or vice to clamp down on the regulator to keep it from snapping. I was going to do the swap myself, but decided it was a PITA.
