rear window motor
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MountainMan, Jan 8, 2002.
  1. MountainMan
    MountainMan Registered Member
    Oct 9, 2000
    89
    Highlands Ranch, Colorado
    Hey all!
    the window in the rear is going VERY slowly, expecially when cold. I got in there and looked around, the gears look well used but not THAT bad... or is it that little black electric motor thing i see that is going bad?
    any thoughts??? anyone else fixed this??? thanks!
    MountainMan Johnson
    86 K5
  2. delta9blazer
    delta9blazer 1/2 ton status
    1,646
    Northern California, over by 7-11
    change your cable now. or, wait a couple of months, and then change your motor and your cable.
    betcha that's it. plus, the cold weather is slowing everything down, so it's very apparent.
    good luck.
    <font color=purple>delta9blazer</font color=purple>
  3. MountainMan
    Oct 9, 2000
    89
    thanks!
    cable, as in the power cable to the motor?
    MountainMan Johnson
    86 K5
  4. MountainMan
    Oct 9, 2000
    89
    also , where am i going to get just the cable? would Schucks have that?
    MountainMan Johnson
    86 K5
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Between the motor and the regulator, you'll find a short cable that is similar to a speedo-cable. The grease in the cable dries up and makes it very hard to spin the cable. The colder the weather, the slower the window runs.
