rear window motor
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 88MudBeast, Jan 8, 2001.
  1. 88MudBeast
    88MudBeast Registered Member
    Nov 8, 2000
    67
    Dallas, TX
    Well, i have known i was going to have to do this since i bought the truck, but i have to get the rear winow motor replaced, or at least looked at.It takes nothing short of an act of God to get the window up or down. Does anybody know where i can get a good cheap motor? or if anybody feels like donating one to a 16 year old, who is broke at the moment, feel free to send it to me in the mail! Anyhow, if you know of anything i can do to to help the thing run a bit smoother let me know please...the less $ i have to spend the better.
    Thanks,
    Big Jake
    Its gunna be a WILD ride!!
  2. chevydude
    chevydude Registered Member
    Dec 10, 2000
    38
    mat-su valley alaska
    if the motor still works but the window goes up and down hard try removing the cover on the inside of the tailgate with window closed you can reach in and clean up a lot of the window crank mechanism, brake cleaner helps a bunch here
    then lubricate it with a light grease the white grease in a aerosol can is what i use but almost anything will work(really honey,i just use the vaseline to fix my blazar with)
    might give that a try before replacing a motor
    marcus
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    There's a cable, maybe 12-18 inches long, that runs from the motor over to the window crank mechanism. It's built like a short speedo cable. Remove that cable and see if you can spin it by hand. If not, replace just the cable. You'll be amazed at how well the window goes up and down. [​IMG] The grease dried up in the one on my '87 K5 and the window would barely move. Installed a new cable and the window worked like brand new.
  4. Itali83
    Itali83 1/2 ton status
    Feb 12, 2001
    795
    Westbrook Maine
    I know how you feel. I'm 17 and had the same prob with my 87 Jimmy. At first I was going to replace the motor. I went to GM but the motors were discontinued years ago, so that was out of the pic. Then I cleaned out the mechanisims and stuff, but that didn't help anything. So finally I just converted the tailgate to manual, but that was about $250, not much help for you, but I did want to tell you that getting a new motor is out of the question. Getting it rebuilt may be an option if that is what is bad but I don't know.
  5. Cavalry
    Cavalry 1/2 ton status
    Oct 1, 2000
    978
    upstate NY(although I cant figure out why)
    If the electric motor and cable are sound inspect the regulator gearbox. The case on mine was cracked preventing the gears meshing. Only about $30 through GM for a replacement.
    Luke
    84 K5
  6. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Check your channel guides for your window, mine are giving me trouble.
    June 2001 - The Texas Sawz All masacre begins. Be afraid rust, be very afraid. [​IMG]
  7. Cusm
    Cusm 1/2 ton status
    Feb 25, 2000
    360
    OK
    If you have to replace the motor, go to <A target="_blank" HREF=http://www.carparts.com>http://www.carparts.com</A> they have them for about $60, whichis cheaper than LMC by almost half. Also check Chyenne(sp?) Pickup Parts.
  8. sarazk5
    sarazk5 1/2 ton status
    Feb 19, 2001
    713
    Sacramento, CA
    there is one on ebay right now, good price as of last night.
