Rear Window "PITA"
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Canuck, Oct 2, 2000.
  1. Canuck
    Canuck 1/2 ton status
    183
    Forrest, Manitoba, Canada
    Rear Window \"PITA\"
    I know there has been lot's of posts regarding an inoperative rear window. My problem is that the window will not roll up or down. The switch works, so the problem is probably motor related.
    My question is, How do you get it down when the motor doesn't work?
    All input is appeciated.
    86 Silverado K5.
    Canuck
    p.s. - PITA - Pain in the A$$
    Go Wide or Stay @ Home
  2. TexasK5er
    TexasK5er Registered Member
    Feb 18, 2000
    44
    Texas
    Re: Rear Window \"PITA\"
    People Ingesting Tasty Animals !!!!
    Nail It!!!!
  3. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    Have you checked to make sure that the window is still in the track. My cousin had a 74 that had some rear window trouble because one side was out of the track. It wouldnt go down but the handle and mechanism were in good shape.
    Have you driven OVER a Ford lately?
  4. rockosangel
    rockosangel 1/2 ton status
    Jul 11, 2000
    277
    Round Rock, TX
    try checking your connections...if it is even a lil undone it may not make good enough contact to get it to function..or it may have jumped out of the track...I would check the connections first, before you start dismanteling the tailgate to get to it.
    Good luck... We had to use a battery and jumper cables when we got ours from a salvage yard and it was up...but you have to make sure it has a good connection or it won't work....let us know what you find out...never know when it will happen.
    http://www.rockosangel.coloradok5.com
    http://www.rocko.coloradok5.com
  5. Truckfan2
    Truckfan2 1/2 ton status
    Apr 10, 2000
    343
    Northern IL
    get in the back of the truck and pull the access panel off the tail gate. undo the cable at the motor and hook up an electric screw gun. This way you can get it down to replace the motor. One other thing, check the safety switch in back... mine was bad so I looped the circut and now it works fine, I just have to be careful not to roll the window up while the tailgate is down.
    Have been stuck (once) as of 8/12/00
    "(2H) Where's all the mud?.(4H)...(4L)..(4H)... oh crap"
  6. tRustyK5
    Jul 23, 2000
    36,170
    1,379
    E-town baby!
    You can undo the cable from the motor and use a drill to raise/lower the glass. I had some wiring fry under the truck and used the drill instead of fixing it[​IMG]
    Rene
  7. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    Grab window firmly from both sides and yank it out of the tailgate. Then buy Skyler, Kayline, or Canback so you won't ever have to worry about it again.
    [​IMG][​IMG]
    Durant, Ok
    '79 Blaze- 350/350/203, 14B w/detroit, D44, 4.11s, 4" susp, 36" TSL
  8. tRustyK5
    Jul 23, 2000
    36,170
    1,379
    E-town baby!
    Amen to that brother!![​IMG]
    Rene
  9. Moose
    Moose 1/2 ton status
    1,062
    Glendale, Arizona
    Latex I TOTALLY agree.
  10. Steve_87K5
    Steve_87K5 1/2 ton status
    May 26, 2000
    521
    central NC
    I thought my elec motor was bad....but cable was rusted inside and the good motor couldn't budge it. Be S U R E to lock the scissors mechanism! Drill a hole thru and temporarily place a screw thru both arms, locking them in position. I learned the hard way and nearly lost a finger.
    SteveB
  11. Canuck
    183
    You know, I'm almost at that stage. The rear window is nothing but a pain in the a$$.
    Canuck
  12. laketex
    6,220
    North Texas
    <blockquote><font size=1>In reply to:</font><hr>
    <hr></blockquote>
    LAKE TEX! Dang it, Steve can I change my username to LT?
    [​IMG][​IMG]
    Durant, Ok
  13. shaggyk5
    shaggyk5 1/2 ton status
    1,610
    SE pennsylvania
    im gonna call you strech from now on.......
    shaggyk5
    aint nuthin in the world like a heavy chevy!!
