Rear Window Problem
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by speedyvision917, May 23, 2004.
  1. speedyvision917
    speedyvision917 1/2 ton status
    May 5, 2004
    472
    CT
    ok my rear window isnt working, anyone have any idea of what it could be? i have the back part off to see inside the hatch and i dont think anythings disconnected. i have an 88 gmc jimmy fullsize
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Do either the key or the dash switch work? If neither are working, sounds like your not getting power back to the motor, or the safety switch went out, or you have a bad ground.
    Grounds are easily fixed by cleaning, the safety switch is easily by-passed, only hard part would be trying wire faults.
    But if you are getting power back to the motor, then the motor might be bad.
    That will give you a few things to check /forums/images/graemlins/thumb.gif
  3. dremu
    Feb 27, 2000
    15,967
    459
    East of San Francisco
    Safety switch is the first thing to check -- they're notorious for failing.
    The dead giveaway is that the window will go down, but not up.
    Fiddle with the latch on the ... passenger side, I think... well, heck, fiddle with both. My experience is that mine stop working every now and again and banging on them sets them loose.
    Do not, however, bang too hard. There's a foot-shaped dent in my otherwise nice CUCV tailgate because of that /forums/images/graemlins/laugh.gif
    -- A
  4. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    I completely took my safety switch out loooooooong time ago
  5. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    sorry for the hijack, but my dads sometimes goes up but will not go down. you mentioned that the safty switch will let it go down but not up, are you sure its not the other way around? where would you find the safty switch. /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif
  6. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    the safety switch is on the inside of the tailgate attached to one of the latches....most people just unplug the wires from the switch and splice them together to by-pass it /forums/images/graemlins/thumb.gif
  7. trailblazer86
    trailblazer86 1/2 ton status
    May 16, 2004
    112
    North Shore of Lake Ontario
    My back window is a pain in the butt also. I am trying to figure a way to install a lift gate like the new Blazers and Tahoe.
    The rear glass is also hard to find. After market glass is safety glass not tempered. Don't touch the edge of saftety glass with anything hard. Also most aftermarket glass has the wrong curve or arc to run smoothly in the tracks.
    I may try some plexiglass to loose some of the weight.
  8. detailer03
    detailer03 1/2 ton status
    Sep 23, 2003
    108
    Arizona
    Also, the cable can be bound up. If it has never been lubed, check it out.
    I have replaced everything but the safety switch in mine. Be careful the regulator is spring loaded to go up. The regulator will take a finger off.
  9. speedyvision917
    May 5, 2004
    472
    CT
    wheres the motor supposed to be located??? went lookin around in back before rippin up the carpet and didnt see anything that resembled a motor, also does anyone no where i can get a diagram of some sort of the back hatch...
  10. dremu
    Feb 27, 2000
    15,967
    459
    Uhh, everything's inside the tailgate. If you have carpet on it, remove it, and remove the access panel on the gate, the one shaped like this
    and it's all in there, though not wonderfully accessible.
    -- A
  11. speedyvision917
    May 5, 2004
    472
    CT
    yaa i have that all open and was lookin in there does anyone have a real diagram of the tailgate*???
  12. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    facing the inside of the tailgate, the motor is located just to the right of the handle and up at the top of the tailgate. Cable runs down to the bottom, around behind the regulator and up the otherside of the tailgate to the transmission(thats just whats its called lol)which is bolted to the regulator.
    Anything else?
  13. speedyvision917
    May 5, 2004
    472
    CT
    hmmm i think i might have found my problem, i dont remember seeing anything there....ill check tomorrow, wats it look like just so i no??? also its weird theres like one big gear that makes the window go up and down but i cant move it manually im guessing the motors supposed to hook up to that but i dunno cuz i dont see a motor
  14. trailblazer86
    May 16, 2004
    112
    I have the exploded view. It would be better for me to send it to you as I am new to this board. Better yet I will post it on my web space and you can download it from there. back with the link in a while
  15. trailblazer86
    May 16, 2004
    112
    www3.sympatico.ca/james.barnes/MyAlbum/Tailgate_Exploded.jpg
    Try this. It is an exploded view of the tailgate.
  16. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
  17. trailblazer86
    May 16, 2004
    112
  18. dleroy43
    dleroy43 1/2 ton status GMOTM Winner
    Jul 22, 2002
    1,517
    Martinsburg WV
    I have been hving problems with my window too. But I went out yesterday and WD-40ed the latches and the safty switch and now it seems to work pretty good. Much easyer than taking it apart /forums/images/graemlins/burb.gif
  19. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    Try opening up the access panel and removing the window regulator cable found at the bottom of the window. Once you get it removed, try pressing the switch and see if you can hear the window motor turning. If it is, then the cable is just bound up from not being lubed. That was all that was wrong with mine, and Muddytazz sold me a new cable for $8.
    -Harrison
  20. speedyvision917
    May 5, 2004
    472
    CT
    whats the cable look like???
