Rear window problem
Discussion in 'The Garage' started by BUEFORD, Jan 5, 2003.
  1. BUEFORD
    BUEFORD Registered Member
    Aug 20, 2002
    15
    NJ
    Has anybody had any experience with a rear power window on an 87 blazer. My window works from the dash mounted switch but the key outside does not.Any body have any experience with what might be faulty and to correct it. Thanks
  2. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    The lock cylinder can go bad quite easily. The terminals inside get wet, then corrode and crumble. Mine were **GONE** when I took it apart. LMC has a replacement for $55 or so.
