Rear Window Problems
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by WinnipegK5, Oct 19, 2001.
  1. WinnipegK5
    WinnipegK5 Registered Member
    Aug 27, 2001
    66
    Winnipeg, MB, CANADA
    I am having problems with my rear window. I can crank it up but when I do only the right hand side goes up, I have to pull the other side up by hand. What is involved in repairing this?? Also the lock cylinder is missing is that tough to replace??
    Thanks in Advance
    Mike
    "Winnipeg K5"
    <a target="_blank" href=http://community.webshots.com/user/ultimike4>http://community.webshots.com/user/ultimike4</a>
  2. ArrowheadK5
    ArrowheadK5 1/2 ton status
    Aug 3, 2001
    252
    Northern MN
    Mine's and '87, maybe this applies, and if I'm wrong someone correct me:
    When my tailgate got real rusty it did that, and still does--
    The window sits on two rails, one on the left and one on the right. If one of those is rusty, it may have broken and now won't push the widow up. Somehow, it holds it up while i'm driving, haven't figured that out yet...
    You can take the access panel off on the inside, then it's pretty self-explanitory.
    Four wheel drive, four wheel expenses...
  3. Burbinator
    Burbinator 1/2 ton status
    Sep 14, 2001
    898
    Tempe, Arizona
    Sounds like the left side is hanging up on something. Like Arrowhead stated, take off the access panel and look around. It's probably an easy fix.
    The learning curve is a toll road...ride with someone who has already paid!
    <a target="_blank" href=http://photos.yahoo.com/abshort1>My Naval Fleet</a>
  4. StoneyK5
    StoneyK5 1/2 ton status
    Jan 4, 2001
    472
    Birch Bay, Wa.
    Do a search on rear window..you'll come up with all kind of fixes and things to look for and helpfull hints..I know, I did. Just my .02
    83K5 Silverado
    What was that bump?
  5. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    OK, I can be your resident know-it-all cause I put one on along with a floor this summer. Haha, j/k, well I guess don't know that much but after having it in a million pieces I have a general idea of this PIA. I would more than likely go with the post above. The bottom of the glass has theses strips that arms of the gear mechanisim rid on to push it up. They use little plastic wheels in those strips so things can move and more than likely one of those wheels has come off or something. Not to bad to think, just pop the cover.
    <a target="_blank" href=http://www.geocities.com/bigkern76>http://www.geocities.com/bigkern76</a>
  6. dyeager535
    26,977
    BTW, you have to unbolt the "regulator assembly" (scissors that the window moves on, and the motor) to get the lock cylinder "housing" off. 4 bolts for the regulator assembly, 2 for the housing. Going to have to find another tailgate for parts though sounds like, the lock cylinder is held in with a weird wave washer. Hopefully it just fell down inside the door though.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
  7. SKI-'84K5
    SKI-'84K5 1/2 ton status
    Oct 11, 2001
    175
    Imlay City, MI
    Had the same problem w/ mine, the metal guides can slide and fall off, just take it apart(access panel) and root around for the guide and put it back on, the reason the windows stay up while driving is that the glass falls between the plastic wheel and metal frame arm and is able to sit in the gap pretty snug, unless you jar it good enough, hope this helps, it's only 2 cents you know
