rear window ratles
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 86blazerk5, Dec 10, 2001.
  1. 86blazerk5
    86blazerk5 1/2 ton status
    Aug 9, 2000
    387
    Hagarstown, Maryland
    Hey guys, I am wondering if anyone else has a bad rear window ratle. Mine ratles at most RPMs and it is rather loud. When i drive alone, i dont notice becuase i usaly have theradio up loud, but when other people ride with me, i have the radio down so we can hear eachother talk, and i haer it verry clearly and it is so annoying. I am wondering if anyone has fixed something like this. I was thinking of opening up the rear window panel and tightening everything down. If that dosnt work, I was thining of replacing all the waether stripping as well... any help is appreciated.
    thanks
    Ike
    Spreading The K5 Gospel!
  2. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    mine does, but thats only when i have my subs thumpin
    <font color=red>K5: Because size DOES matter</font color=red>
    85 K5 4IN LIFT 35 GOOD YEAR WRANGLER MT/R, AMERICAN RACING WHEELS
  3. vince13
    vince13 1/2 ton status
    Dec 6, 2001
    105
    Penticton, BC Canada
    it depends on what is rattling, it could just be the release mechanism for the tailgate if it is just get yourself a piece of solid and round foam about 1 1/2 diameter and drill a small hole in it cut it length ways and put it ove the release mechanism, if its not that go thru and check everything and make sure it is tight. hope that helps. let me know
  4. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    It is probably out of the sash at the bottom. The sash is kinda like a metal bracket that holds on to the glass. It is suppost to be held in with this stupid rubber stuff and if it gets worn it will rattle like mad. You can get new rubber from your local GM dealer... then I suggest some advehsive or glue on the rubber to hold it all together. Mine was still kinda loose afterwards and could be pulled out so I did it up tight. But no rattles. Also check the weather stripping is holding it tight and that you don't have anthing that would be making the tailgate move around like loose bolts, rusted out florr, etc.
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://coloradok5.com/gallery/captcrunch>http://coloradok5.com/gallery/captcrunch</a>
