Rear Window Regulator Replacement for 84K5 Manual Crank
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 84blazerwhoopee, Feb 25, 2004.
  1. 84blazerwhoopee
    84blazerwhoopee Registered Member
    Feb 13, 2004
    36
    Minneapolis, MN
    Can anyone give a clueless dude instructions in replacement of this thing? I am going to get it this Friday and try to install it asap before my daughter and I leave for a trip.
    I know nothing about body repair but I do have some mechanical ability. I can start a car two out of three times......
    Randy
  2. funkycold
    funkycold 1/2 ton status
    Apr 22, 2002
    435
    Orange County, CA
    I just replaced the same thing in one of the Suburbans. Check the following link for instructions.
    window regulator
    /forums/images/graemlins/waytogo.gif
  3. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    I just did it agian in my 76. The directions are pretty good in that link. But I don't take the window out. with the tailgate down, cover plate removed, put the window about 1/2 way up. Remove the 4 little bolts that hold the window onto the tracks. Use a saw horse or something similar to support the window and pull out to the "almost up" position.
    in order to get the window out, the sash/window seals need to come out. They can be a bi%$h! this way, you don't have to screw with them! The rails are opened up at one end so you can remove them for the rollers. Then there are 4 bolts that hold the regulater in. baddabing. it's out.
    /forums/images/graemlins/waytogo.gif /forums/images/graemlins/waytogo.gif
  4. 84blazerwhoopee
    Feb 13, 2004
    36
    Minneapolis, MN
    Thanks Fubky! Those pics were a HUGE help!
    Rando /forums/images/graemlins/bow.gif
