Rear Window Regulator
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by WinnipegK5, Nov 12, 2001.
  1. WinnipegK5
    WinnipegK5 Registered Member
    Aug 27, 2001
    66
    Winnipeg, MB, CANADA
    Is there an easy way to realign the marks on a rear window regulator?(manual type) The glass was coming up uneven because the left side arm was 3 or 4 teeth behind the right. Does this mean the regulator is shot? or can I "reset" it? Does this question make any sense ?? Anyone had this problem?
    Thanks in advance.
    Mike
  2. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    It makes way too much sense..... I tried for days to reset mine with no luck. I got mine new from the dealer for 75$, only because Ik new the markup was about 50% and I decided to be as full of it as they were, so shop around and if you need it now I suggest putting it back together and not rolling it down, til you find one.....hope this helps, sorry.....
    <font color=blue> I'd rather have a bottle in front of me, than a frontal lobotomy!
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Sounds like there is a tooth or two missing from one of the geared plates that lift the window. Mine had the top couple of teeth messed up from getting cranked hard to seal the window up real tight. It would just click when it got to the top. I took mine apart and welded a bit of metal back onto the boogered teeth and filed them to the right shape. Fixed it right up. [​IMG]
    You'll need to figure out what is stripped, then realign everything and then fix the teeth. (Or just buy another regulator assembly). [​IMG]
  4. chevyfumes
    Feb 24, 2000
    38,584
    266
    yup wish I had a buddy like you to put it all together when it was junk...... they can be rebuilt if you have the ability and the means... no matter what it's a pain, hang in there
  5. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    It's easy! You just apply the cost savings towards tools! [​IMG] Eventually, there's no room to work in the garage, 'cause you have too many toys in there. [​IMG]
