Rear window roller rivet install
Discussion in 'The Garage' started by shepdog, Aug 26, 2006.
  1. shepdog
    shepdog Registered Member
    Jul 16, 2006
    35
    TRACY,CALIFORNIA
    I just bought some roller rivets from LMC for my rear power window on my 86K5. I grinded off the old ones and when I went to insert the new LMC ones they are quite a bit smaller in diameter. Anybody else had that problem? Should I heat the rivets up and smash them flat with a hammer or is ther another process? Maybe I should just order them through the dealer I don't know, but that rear window is a pain in the rear.
  2. Smokin'Joe
    Smokin'Joe Registered Member
    Jul 27, 2006
    50
    Butler,Pa
    NO!! Do NOT heat them, you'll melt the plastic. I know, I've done it..:doah: When I did mine, I found a rather large punch that I somehow ended up with. The idea is to set the metal like a rivet, expanding the metal to fill the gap to make it tight, then to lay the excess length over. Don't know if this is the best way, or not. But that is how I did mine ( the second time) two years ago. Hope that helps:rolleyes:
  3. shepdog
    Jul 16, 2006
    35
    TRACY,CALIFORNIA
    Ok so I place a large punch in the center of the rivet and hammer away on the punch-squashing the rivet out?
  4. Smokin'Joe
    Jul 27, 2006
    50
    Butler,Pa
    Something like that. The punch I used was at one time ( I think ) A Chisel. It was something I aquired from my dad. It is roughly an inch around, with 6 flat sides. My dad used to run a garage in Carlsbad, New Mexico back in the 60's, and modified tools if he needed something that wasn't made. In this case a big punch. I used it to expand the metal, and to start it flaring out. I used a ball peen hammer afterwards. Guess which side? After it was smushed so far, I used the flat peen to finish. I had taken my time, trying not to tear it. Good luck.
  5. ssped
    ssped 1/2 ton status GMOTM Winner
    Jan 5, 2006
    1,529
    Mission Viejo
    Not looking at this can you just use a bolt and nut through the roller and squash the rivet?
  6. Smokin'Joe
    Jul 27, 2006
    50
    Butler,Pa
    The punch was what I used. Yeah. Don't see why not...
