Rear window switch question/idea
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Pugsley, Sep 8, 2001.
  1. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    My tailgate switch has once again taken the big dirt nap - I have the capability of rolling it up from outside, but not down. Not wanting to undertake changing the #$%* thing again, I came up with an idea - Why even mess with the OEM setup? I could get a piece of aluminum machined into a new bezel, and install a keyed DPDT momentary contact switch and be free and clear of that problem child OEM switch for good. Is there any reason that this wouldn't work?
    1 tequila 2 tequila 3 tequila Floor
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  2. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    Sounds good, you know they build things to break so they can create more money... We build/ fabricate/ modify/ rejuvinate/ create/ recreate in an attempt to be the baddest mofo's on the planet and have the things we build outlast our childrens children or atleast until the next time we need to fix them[​IMG]besides dudes who build they're own SH!T rock[​IMG]
    <font color=blue> I'd rather have a bottle in front of me, than a frontal lobotomy!
  3. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    What is the DPDT switch you are talking about? Off topic, what size tubing is your bumpers? I can only afford to get one die with my bender and I've been thinking 1.5" die.
    Bubba Ray Boudreaux,
    Leader of the Advance Party for
    the CSA revolution in the PRK!
    <a target="_blank" href=http://community.webshots.com/user/mdntrdr1>http://community.webshots.com/user/mdntrdr1</a>
  4. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    ...or how about a keyless entry unit? One button to lock/unlock the doors...the second button (usually for a trunk) to open/close the back window......add a "one touch" unit from Autoloc.....then an alternate action on the pushbutton....push once to open...push again to close....might be cool.
    Michael[​IMG]
    <a target="_blank" href=http://www.jmartin.net/parker/goose.htm>www.jmartin.net/parker/goose.htm</a>
  5. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I was thinking of the "coke machine" type switch like used on elevator overrides http://www.lockingsystems.com/SwitchLocks.htm
    BTW - my bumpers are 1.75" OD
  6. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I thought of that too - I might add it in eventually, but I still have to do something with the existing switch, or it'll drive me bonkers. Ever since I disabled my cruise control, the mere fact that I still have the button that doesn't do anything annoys me to no end. I'm just anal retentive that way[​IMG]
  7. MudNurI
    MudNurI 1/2 ton status
    Jul 15, 2001
    2,113
    VT
    I'm lost by the posts, is it ths switch in the dash you are talking about? Mine was toast, its now a toggle , I'm planning on moving it over next to the headlight switch, with two more toggles for my driving lights. The remote entry feature sounds nice, but would just end up with more problems then you have now. The "connector" for the wires in the back was no good either, went and got a trailer wire harness, and switched those, since then, haven't had any problems.
    1986 K5 4" skyjacker suspension 3 " body, 14 bolt rear,(sitting next to truck) 12 bolt (still in truck) dana 44 front, TIRED ol 305----
  8. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I'm talking about the one on the tailgate - I've replaced it twice already, and it's dead again. I figure that I could brew up a replacement setup, and be free of this problem for good.
  9. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    Something to keep in mind is the amp draw the switch sees. The switch is in-line in the circuit, so it sees every amp the window motor pulls (at least on my '87, anyway...). Maybe a relay in the tailgate to handle the electrical load will extend the lifespan of the switch...??
    It's a happy day in Marine Aircraft Group 49... 405 is ALIVE!!
    [​IMG] <font color=green>Semper Maintenance!<font color=black>
