rear window switch
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 76_gmc, Mar 16, 2007.
  1. 76_gmc
    76_gmc Registered Member
    Feb 19, 2007
    30
    Enterprise, AL
    Can anyone help me in locating a power window switch for my 84 K5 Chevy Blazer. The window will go down, but not up!
  2. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    There is a switch inside the gate that wouldn't allow the window to go up if the gate is open. Sometimes these switches go bad and other times they just need an "adjustment" with a swift rap with a screw driver handle.
  3. Disturban
    Disturban 1/2 ton status
    Mar 9, 2006
    120
    Phx,Az
    If that don't work ...try LMCtruck.com they have all kindsa oem type replacement stuff.
  4. 76_gmc
    Feb 19, 2007
    30
    Enterprise, AL
    Thanks, LMCtruck.com has everything I need and want!
  5. Disturban
    Mar 9, 2006
    120
    Phx,Az
    yes it does ! that's one of those sites where ya hafta be careful not to spend millions!
  6. skyyk5
    skyyk5 1/2 ton status
    Jan 2, 2007
    1,537
    N.E. PA
    X2 I just bypass all mine. The thermal switch can give you problems if the window is sticking alittle going up. Both mine are bypassed, but with my fulltop, the window goes up in the winter (after 30 minutes of anger) stays there till spring.:haha: Then it's soft top season.:D
  7. AZ79K5Project
    AZ79K5Project 1/2 ton status
    Jan 15, 2006
    2,082
    Arizona
    While you're in there, check to make sure the rails are lubricated. They tend to get sticky and this may also contribute to the window being slow or getting stuck going up if the motor is alive and trying to work.
