Rear window switch
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 90K5, Sep 28, 2002.
  1. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    OK - my rear window sometimes will stop working, from both the dash switch and outside the truck. Trying to roll it up or down using eithr one doesn't help.. thinking there is a bad switch somewhere in there, anyone kow where it is? its pretty dusty out here, wouldn't be surprised if it juts got dirty...thanks
  2. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    There's a safety switch on the driver's side of the tailgate on the inside, that might be it.
  3. gotmud?
    gotmud? 1/2 ton status
    Feb 23, 2002
    1,172
    up north
    follow the wires to where the factory crimps are cut them out and re-splice, I had this problem too and that fixed it, good place to start anyway.
  4. gotmud?
    Feb 23, 2002
    1,172
    up north
    I think that would only prevent it from going up, not both
  5. trouble1
    trouble1 1/2 ton status
    Sep 28, 2002
    346
    travelling, probably lost
    Good luck...I've replaced both my switches (front and rear) ran new wiring, replaced the tracks, and got a new motor and still have occasional blackout periods where it just dont wanna work.... /forums/images/icons/frown.gif
  6. mattyblazer
    mattyblazer 1/2 ton status
    Sep 22, 2002
    202
    Long Island, NY
    There is a light blue wire ( at least in 87 ) that goes high up in the tailgate on the drivers side. there is a shitch there that tells the motor that the gate is open or closed, you can jump it out or shoot it with wd 40 and it should start to work better. It did for me.
    Matt
    Also the re-splice of the factory crap is a good idea.
  7. schwank
    schwank Registered Member
    Dec 7, 2001
    28
    PDX, OR
    Had the exact same problem about 6 months back... was actually reversing the polarity on the wires to make the window do what i wanted, cause it wouldn't co-operate. Of course now my cable busted, so I wait on the part to arrive.
    As previous posters have metioned the rear window lockout switch is located underneath the latch mechanism on the drivers side. The LMC Blazer catalog has a great blowup of the thing.
    I decided to not blow another 25 bucks on a replacement, as common sense would dictate that you don't roll up the back window with the tailgate open. That's just me, if you think that's a problem, go buy a new switch. Otherwise splice the blue wire running up to it, and voila back in action...
    In case you need it, here's the wiring diagram given to me
    rear window wiring diagram
