Rear window switch
Discussion in '1936-Present Suburban' started by chvyhs, Oct 2, 2002.
  1. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    My rear window swich doesn't work anymore. I'm talking about the key swich in the tailgate. Anyone fix this problem before? /forums/images/graemlins/1zhelp.gif
    What does rotfl mean? And what the hell is this? /forums/images/graemlins/k5.gif It's missing a set of doors!
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Yeah, i had to completely take mine apart and clean off the contact points inside the switch and its worked great ever since. /forums/images/graemlins/thumb.gif
  3. BurbLover
    BurbLover 1/2 ton status
    Jul 31, 2001
    3,060
    SW Missouri
    If your window is up, this can be a PITA!! To get to mine, I had to crawl into the rear, unscrew the inside of the tailgate. Then disconnect the window. Then drop the window so that I could open the tailgate to work on it. It wasn't much fun, especially the hitting my head on the roof parts!!
    /forums/images/graemlins/ignore.gif
  4. BigBluOx
    BigBluOx 1/2 ton status
    Aug 30, 2001
    301
    Auburn, WA, USA
    /forums/images/graemlins/thumb.gif I couldn't resist the temptation, so I made a 'Burb outta /forums/images/graemlins/k5.gif. If anyone wants it, I can email it to ya as I don't have it posted anywhere yet. My email is in my profile.... EDIT: Try this... /forums/images/graemlins/burb.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
    Jon
  5. chvyhs
    Feb 12, 2001
    1,469
    Thanks,
    My window still goes up and down with the inside switch.
    I now see the Sub in the instant gremlins.
    So what does ROTFL mean?
    /forums/images/graemlins/burb.gifWE RULE!
  6. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    ROTFL - Rolling On The Floor Laughing
  7. Ddragggon
    Ddragggon 1/2 ton status
    Apr 25, 2001
    2,657
    Hartford, WI (formerly Etiwanda, SoCal)
    hooray! /forums/images/graemlins/burb.gif
    -Rich
  8. Great78burb
    Great78burb Registered Member
    Sep 24, 2002
    28
    San Diego, CA
    I tried to fix mine today. It would go up, but not down with the key. It's pretty easy to get to, just a pain in the @ss! It turns out I need a new switch. The contacts on mine are too far gone. /forums/images/graemlins/frown.gif Oh well, I guess I just have to use the switch inside from now on! /forums/images/graemlins/burb.gif
  9. FLASHLIGHT76
    FLASHLIGHT76 1/2 ton status
    Jun 20, 2002
    255
    OREGON
    I do so love my barn doors. /forums/images/graemlins/smirk.gif I seam to never have to deal with such issues as: My rear window won't go up or how do I keep the exhaust out of my truck. /forums/images/graemlins/tongue.gif I'm sure I'm going to look like this /forums/images/graemlins/ignore.gifwhen someone with a tailgate sees me! /forums/images/graemlins/grin.gifLOL
  10. Ddragggon
    Apr 25, 2001
    2,657
    you may not have window sticking problems, but I don't have a blindspot dead center of my rear. not only that, I can sit on the tailgate, and it makes a great work bench. the only time I curse my tailgate, is on the lifted K20, when I have to try and reach inside ( not often) and I don't have any trouble with exhaust getting in, now that I've fixed my exhaust system. the other positive thing, is I can drive with the window down, and get some wicked awesome cross ventalation.
    -Rich
  11. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    I fixed mine. The first problem was the burnt out fuse /forums/images/graemlins/smirk.gif
    The second was the latch sensor. I found that if I pound my fist on the tailgate near the right side latch while the key is turned, it will miraculously work again /forums/images/graemlins/grin.gif
    A problem I still have is the tailgate handle. The linkage must be bent or something? I took off the inside panel and pull on the rods manually to open it.
    When the tailgate packs it in, the barn doors go on /forums/images/graemlins/wink.gif
    My '77 parts Burb has barn doors, but it looks like the rear sill and hinge pillars are different on my 84. Has anyone successfully converted? I'll tackle the endeavour when the time comes, but a heads-up is always nice /forums/images/graemlins/smile.gif
  12. Ddragggon
    Apr 25, 2001
    2,657
    from what I;ve read/seen/been told, all you need to do to convert to barn doors, is remove the upper fiberglass portion where the tailgate window rolls up into, knock out the plastic nubs that cover the door hinge bolt holes, and bolt the doors on. the sill plate might be different, but should also be simple to unbolt/bolt on from the other truck.
    -Rich
  13. FLASHLIGHT76
    Jun 20, 2002
    255
    OREGON
    Draggon,
    LOL! /forums/images/graemlins/rotfl.gif Yeah the center post is a bit of truble but once you lift high enough your prettymuch relying on your side mirrors anyways /forums/images/graemlins/grin.gif I just tinted the rears and use the side mirrors. would love to figure a way to make the side rear windows open like vans (from the bottom)
