Rear window workings
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by sled_dog, Jan 8, 2003.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    My rear window goes up and down pretty hard. The truck came with a crank gate but it was rusted out so I replace ti with an electric one when I restored the body. It has always worked slow, I got another motor from a junkyard thinking mine was worn and weak but it didn't help much. I put in a new battery and it worked a little better but not much. Every couple weeks it gets stuck at some point in the up down process and I have to take it apart and lube it up. The scissor arms seem to rub against the window slide parts and bind up over time. I just spray some white lithium on there and run it up and down with a cordless drill and go for a couple weeks. Anyone know if this is a common problem? any suggestions?
  2. chev4life
    chev4life 1/2 ton status
    Jun 21, 2001
    416
    San Jose, CA
    Mine on my '87 works very slowly also...sounds like it is going to die constantly...but always continues to work. I have yet to have it stick on me...but I recently pulled the gate apart and used a tub fo lithium grease on all sliders and moving parts, helped a little but not a bunch. I just think the motors are way under powered and design is a little weak for the size of window they have to move. I would like to know if anyone has figured out a better way.
  3. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    yeah that sounds like mine but every once and a while it does stop. Have to break out the cordless drill and the white lithium.
  4. mtnman4x4
    mtnman4x4 Registered Member
    Mar 2, 2002
    88
    Yukon, Oklahoma
    Well thanks for answering that question. I was just getting ready to buy another motor. Mine does the same thing and it also stops about 3/4 of the way up, but only when it feels like it. /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif
  5. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    same place mine stops and slows down most. If you open up your gate you will see this is the point where the window slide attached to the glass slides over the scissor part and it rubs BIG time.
  6. dyeager535
    26,977
  7. tRustyK5
    Jul 23, 2000
    36,169
    1,368
    E-town baby!
    When everything is right inside the glass goes up and down in under 4 seconds..at least mine does/forums/images/graemlins/thumb.gif
    The tracks on the sides are supposed to have felt which reduces friction and keeps the glass from hanging up on the mechanism...
    The bars attached to the glass have UHMW rollers that commonly end up with flat spots...
    Rene
  8. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    in the diagram on my truck number 44 is rubbing against the scissor arm thing that 29 and 30 attach to. Its definetally rubbing heavy cause I can watch it when i use the cordless adn there are visible scrapes on the arm.
  9. will89
    will89 1/2 ton status
    Oct 21, 2002
    104
    nomad
    So you don't have to take the whole thing apart..... try centering the window every so often. Roll it up about half way then grab it on each far end and slide it back and forth until you've centered it. At that point it will have about 1/2 and inch of right or left movement. I find that mine will come off center once in a while and then meet a lot of resistance on one side or the other. I wish I had barn doors!
    Ive done everything else that you guys have...New motor, regulator, nice new soft felt swipes, key switch etc.. its just a poor design.
    I'd also recommend giving the motor a little help by pulling up on the window a bit when you're raising it.. it will last a longer.
  10. tRustyK5
    Jul 23, 2000
    36,169
    1,368
    E-town baby!
    Inspect the side tracks that the glass slides up and down in (looks like number 48 in dorians diagram) There should be a felt guide glued in that track. It's pretty common for the felt to be missing entirely...and that is a big part of interference inside the gate.
    Rene
  11. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    I would give it a hand but my key doesn't work. Can only operate the window from the switch mounted next to the headlight switch.
  12. dyeager535
    26,977
    If you like, you can search for my tailgate post a few months back, I had the same problem as you, key didn't work. Easy fix once you dig in.
  13. JakeInAZ
    JakeInAZ Registered Member
    Jan 11, 2003
    21
    Near Prescott AZ
    VERY COMMON....it's as common as left blinkers that won't shut off automatically and scratched rear windows. I've torn mine completely apart and replaced the guts AND glass and it worked for a month and now does the same thing. The only way I can get it to go up when it sticks (only sticks when rolling it up) is to get out and "jiggle" the tailgate a little...and since it's all new and TIGHTLY installed there isn't much reason for it. Just be lucky that your blinker shuts off, your brakes don't rattle yet /forums/images/graemlins/smile.gif
  14. smack
    smack 1/2 ton status
    Feb 24, 2000
    277
    Colorado
    What we all need is some brainiac to build us a torque doubler or an electrical engineer to find a way to double the output of the motor.
    Gotta be someone out there with some brains!!!
  15. mattyblazer
    mattyblazer 1/2 ton status
    Sep 22, 2002
    202
    Long Island, NY
    My Buddy replaced the wires from the switch and battery with 10 guage marine grade wire, which in turn increases current flow, and cured his slow gate problems. I got the wire but much like every thing else have not got to it yet.
    -Matt
  16. RLBstein
    RLBstein 1/2 ton status
    Jul 2, 2000
    179
    Pensacola, FL
    Thats exactly what I did. Replacing the wire helped a lot. Also, the window channels that SHOULD have the felt in them is missing on mine. I just crammed it with graphite lube like I did the rest of the window mechanism and mine works better now than it ever has, but I always try to have the engine running when doing it to give it more juice.
  17. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    I found sometimes if you rev it up to like 2000RPMs while puting the window up it goes faster.
  18. Overkill
    Overkill 1/2 ton status
    Jan 15, 2002
    284
    Orlando, Florida
    A quick google search and I found this http://www.redarc.com.au/vb.htm , it shoud work awesome for boosting voltage to your window motor. I didn't look at it too long and didn't see a price. Im sure it's expensive but there are posibilities for manufactured voltage boosters.
  19. K5Psycho
    K5Psycho Registered Member
    Jan 6, 2002
    55
    FL, USA
    i took apart my rear panel and lubbed it up nice with grease and it is nice and slick goes up and down in like 6 secs dunno sometimes it still hums going down lol
  20. creampuff90k5
    creampuff90k5 1/2 ton status
    Feb 15, 2002
    142
    New Jersey
    If you haven't done so already, try replacing the drive cable between the motor and regulator. Makes a HUGE improvement for about $25.00 from your dealer.
