Rear Window
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 85K5MT, Aug 5, 2001.
  1. 85K5MT
    85K5MT Registered Member
    Jul 22, 2001
    7
    Missoula, MT
    I just traded my '85 tired 305, slipin 700r for a '88 350, 4 speed, all crank windows. The question I have is the rear window doesn't go down all the way it has about 3" sticking up. I removed the panel to see if something was in a bind, it all looked OK. When the window is cranked down as far as it will go the rollers that slide in the channel on the bottom of the glass are all the way to the end. Is this common for crank a window or is there a way to fix?
    Chas.
  2. SWAMPRNR
    SWAMPRNR 1/2 ton status
    Apr 7, 2001
    296
    Temple Texas
    Some Back Side Door Windows Are Made Like That On Suburbans.
    The Back Window On Blazers Go All The Way Down Unless Something Jams .
    A BIG HAMMER CAN FIX ANYTHING ..
  3. Tybee
    Tybee 1/2 ton status
    Mar 25, 2001
    1,565
    Centennial, CO
    Mine sticks up about an inch, im afraid im gonna break it dragging something over it. It looks like its all the way down inside though.
    Theres nothing like fiddling with my Jimmy! 1984 GMC Jimmy 379 diesel, 700R4, 3.73s, 31 x10.50 x 15
  4. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    mine sticks up also, i just removed it when i took the top off.
    Check out my 73 K5 <a target="_blank" href=http://members.theglobe.com/xnoahx/73k5.htm>http://members.theglobe.com/xnoahx/73k5.htm</a>
  5. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    if it stick out a bit then you need to basicaly remove the mechanism for the roller and rebuild it. it has fallen out at one time and put back in wrong. it will go all the way down. mine did this. basicly before you do anything make sure the full track is being used... I.E. in the up position, is it all the way up?
    1974 Chevy Blazer Cheyanne. lots of plans for it....
    but it is on 33's now, with saggy old springs. i am in so cali if ya got any parts for me.
  6. 85K5MT
    Jul 22, 2001
    7
    Missoula, MT
    Thanks guys for all the replies I'll go pull it apart again and check all the track, thanks again.
    Chas.
