rear window
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazen_md, Dec 12, 2001.
  1. blazen_md
    blazen_md 1/2 ton status
    Aug 20, 2001
    129
    MD
    I have a 90 k5 6" superlift 35" ssr's and my rear window it works from the switch inside but the key switch outside does not work and I was wondering if anyone has experienced this problem and could give me a few tips thanx.
  2. 81Bogger
    81Bogger Registered Member
    Dec 2, 2001
    64
    Kalispell, Montana
    my key doesn't work either.............never really bothered me, but I would first look at the contacts where it connects to the key unit in the tailgate, the ground, or possibly the whole unit itself......worse case pick up a junker, swap out the key unit and use a different key for the tailgate....just my $.02
    <font color=red>81</font color=red><font color=blue>Bogger<font color=blue>
    "<font color=blue>Mud under tire, and Fords in the rear view...<font color=blue>" [​IMG]
  3. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    Same problem here, I took it apart and the lock cylinder contains the electrical connections that control the window from outside the truck. This gets moisture in it and corrodes. Mine was so bad I couldnt get the key in the lock. You will need to pull it apart and eaither clean the connections out or if its too bad get a new lock switch..LMC has them for like $50 or somthing...
  4. dyeager535
    26,975
    Check that the switch is getting voltage. IIRC, there are two plugs for the tailgate, one 12V always, and two that are the wires from teh in-cab switch. The plugs are under the drivers side of the tailgate. No reason to rip the whole tailgate apart if the problem isn't the switch. I've got a tailgate keyswitch gremlin too, but its somewhere up near the cab/firewall, as I don't get constant 12V back there.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
  5. blazen_md
    Aug 20, 2001
    129
    MD
    Thanx guys for the reply its not really that big of a deal to me either but something I would just like to get working again.
