rear Window
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dgface, May 19, 2002.
  1. dgface
    dgface Registered Member
    May 12, 2002
    39
    McDade,Texas
    Can someone tell me if the rear window can be raised manually to repair the cable to electric motor? My cable is broken but the motor is fine and the window is all the way down. The cable is broken and will not work in a drill. Thanks
  2. YtseJam
    YtseJam 1/2 ton status
    May 19, 2002
    147
    CT USA
    Put the cable end in a drill, then forward or reverse it to go up or down.
  3. dgface
    May 12, 2002
    39
    McDade,Texas
    The cable is messed up and I tried it in drill before and cable messed up even more
  4. Overkill
    Overkill 1/2 ton status
    Jan 15, 2002
    284
    Orlando, Florida
    I sounds like you may have to remove the whole window assembly. Im not sure how to do this but it would give you great access to the gearbox and broken cable. Good luck.
