Rear window.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by SwedeBlazer, Oct 11, 2002.
  1. SwedeBlazer
    SwedeBlazer Registered Member
    Aug 15, 2002
    7
    Sweden
    Is it the same rear window on a -74 Blazer and from a newer Blazer?
    I moust get a new one, and here in Sweden is it moust likely easier too find a window from a newer Blazer.
    Thanks.
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I believe that it was the same up till 91.
    After that I am not sure if they retained the same with the full body no removable top model.
  3. gotmud?
    gotmud? 1/2 ton status
    Feb 23, 2002
    1,172
    up north
    3rd gen window's are different, they swing up don't they?
  4. 4x4swede
    4x4swede Registered Member
    Sep 10, 2002
    61
    Sweden westcoast
    Kolla med Osby bildelar, den skroten brukar ha massor med delar till gamla /forums/images/graemlins/k5.gif
  5. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    WTF? /forums/images/graemlins/confused.gif
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Er, Uh, Hmm.... Yeah! What he said! /forums/images/graemlins/thumb.gif
  7. gotmud?
    Feb 23, 2002
    1,172
    up north
    Eric what do you mean WTF? /forums/images/graemlins/tongue.gifare'nt 3rd(92 up) gen rear window's like the s-10's on a hinge at the top?
  8. sinchphoto
    sinchphoto 1/2 ton status
    Mar 7, 2000
    366
    Southern California
  9. gotmud?
    Feb 23, 2002
    1,172
    up north
    sinchphoto,Thank You......Eric /forums/images/graemlins/tongue.gif /forums/images/graemlins/grin.gif
  10. SwedeBlazer
    Aug 15, 2002
    7
    Sweden
    Thanks to you all.
    Och tack till dig 4x4swede, jag ska kolla med Osbyskroten.
  11. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    Yes all second gens 73-91 are the same and should be interchangeable. I have done the research to replace mine. Someone told me that the Suburbans are different but the glass in my blazer is from someone that pulled it out of a burb (so he says, but it fits) CHECK the angles on the sides on the glass and the mounting base.
  12. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    yeah I have a 97 yukon, same body style as the 92-up blazers,tahoes,yukons... They should have the rear glass that lifts up on hinges, unless you got the barn doors offered as a special order I think.
