Rear Window
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MILOLGJC, Dec 23, 2002.
  1. MILOLGJC
    MILOLGJC Registered Member
    Sep 27, 2002
    29
    FL
    I have a 76 K5 and the rear window has ceased manual operation. I doesn't roll up or down with the manual crank handle. I have taken off the inside panel and can't really see the mechanism that moves the window assembly. Anybody have any experience with this and knows what the fix entails. Thanks!
  2. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    Most likely your regulater is busted , that is what makes it go up and down. Should be about 150.00 part #38-6588 from LMC . Your going to have to start tearing into it before you can be sure though, good luck... /forums/images/graemlins/thumb.gif
  3. doctor4x4
    doctor4x4 1/2 ton status
    Jan 22, 2002
    1,450
    Los Angeles
    same thing happened to me about 9 - 10 years ago :-) i can now play name that part with the tailgate any way ill pm ya my nu and i allways have a few good manuel regulators around (just in case ) so send me a e if ya want me to help ya on this 1
    Randy
  4. CooknwithGas
    CooknwithGas 1/2 ton status
    Nov 27, 2001
    332
    Istanbul, Turkey
    You should get out your tools and start taking it all apart. I rebuilt my entire tailgate and although it was a challenge, it all works great now. The first thing you should do is clean everything up. You can see right away which parts are worn and not working. There are two little plastic rollers that should be round, but are probably rectangular. The regulator has a big spring on it and some gears. clean these really good and free everything up.
    It goes back together pretty easily. Just go for it and you won't be sorry. If you leave it like it is and keep wrenching on the handle, the handle will break. Make sure everything is operating freely before you put it all back together.
    Good luck.
