Rear Window...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by RustBuket, Aug 15, 2003.
  1. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    Well I just bought a blazer and I think its pretty sweet but the rear door doesn't open and I think its because the window doesn't go down all the way. The window goes down till the top of the glass is about 3-4" about the tailgate...is this right? If not, how should I got about fixing this? /forums/images/graemlins/confused.gif
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    My tailgate window did that when I first bought my rig, come to find out, the regulator was missing a few teeth on the gears so that is where it stopped. So my first guess would be to check the regulator for missing teeth.
  3. ArrowheadK5
    ArrowheadK5 1/2 ton status
    Aug 3, 2001
    252
    Northern MN
    on my blazer (that I sold /forums/images/graemlins/mad.gif) the window wouldn't go down, either (rust). I am not sure if it's related to the door latch or not... but you should be able to open the door by taking the plate off the inside of the gate and pulling on the two rods that extend from the handle to the latches on either side... I believe you can just pull up on them from outside the truck.
    Good luck!
    Tom
  4. dyeager535
    26,979
    Figure out why it doesn't go down all the way, and fix that, then it will open correctly.
    You can pop the access panel off from the inside, and pull the two "rods" towards the center of the tailgate to unlatch it, so you can work on it easier.
    The tailgate won't unlatch (with the exterior handle) if the lower edge of the window doesn't engage the lever at the bottom of it's travel.
  5. RustBuket
    Feb 21, 2003
    1,618
    Alright, well I'll get to that l8r when I get the new engine in place.
