rearc or replace
Discussion in 'OffRoad Design' started by 72jim, Jul 2, 2001.
  1. 72jim
    72jim 1/2 ton status
    Jul 2, 2001
    110
    tempe,az now in portland oregon
    i have a 72 jimmy with a 4" lift 35" bfg's 350/350 and i'm pretty sure 4:10 gears. it's a rough country lift and the springs are now flat,my truck rides like a log wagon and i need to fix it.is rough country worth the rearc or should i replace the lift? if so with whose lift?
    <P ID="edit"><FONT SIZE=-1>Edited by 72jim on 07/04/01 01:26 PM (server time).</FONT></P>
  2. morphed86k10
    morphed86k10 1/2 ton status
    Jun 25, 2001
    463
    Reno Nevada
    all the experience I've had with rearced springs is bad. Spring steel has a memory, and the springs usually lose a noticable amount of arc.
  3. Greg72
    Mar 5, 2001
    15,681
    1,392
    642 Days to BB2018
    I'm glad to hear it's not just me....I have set of Rough Country springs too (4" lift) and they ride terribly. Whenever the front hits a bump it feels like the whole front end is coming off the ground. My front leaves look completely flat (no arch). I thought it might have been from the addtion of a big block motor (more weight) but from your comments, maybe it's because of the Rough Country springs.
    A lot of guys here seem to like the Tough Country springs. They are some of the softest riding springs you can get, and people seem to like them. Not too expensive either, so that's probably what I will try next.....that, and a shackle flip for the rear. That allows you to remove the blocks, but still get a 4" lift with a stock spring. Should help things ride smooth in the back also. ORD sells the shackle flip as well as the Tough Country springs. They also add in some parts for the springs that aren't normally included when you buy from a typical "mail order" shop, so it's probably worth the extra few bucks....
    -Greg72
  4. kumma
    kumma 1/2 ton status
    Oct 29, 2000
    380
    Novi, Michigan
    How long have you had the lift springs on your truck. Im curious because i'd like to know how long they last.
    "Why is there a <font color=red>watermelon</font color=red> here?"
  5. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    I've had decent luck with re-arched springs, but I would just recommend getting some new lift springs. Re-arching should work with lower arches, like re-vamping stock springs, that kind of thing. For a lift spring, you should just get new ones. Keep in mind that some lift springs will be mostly flat at ride height, but ride quality is determined by the number and thickness of leaves in the pack. Rate won't change as they sag, just ride height.
    Making the world better, one truck at a time.
    [image]http://offroaddesign.com/images/tracks1.jpg[/image]
    SW-ORD
  6. 72jim
    Jul 2, 2001
    110
    well i baught the truck about 11 months ago and the guy i got it from said the lift was about 2-3 years old. i don't know about the quality of other lifts just the one thats on my truck
  7. 72jim
    Jul 2, 2001
    110
    right on, i'll check it out. thanks
  8. 72jim
    Jul 2, 2001
    110
    thanks for the info.every bit helps
