REAREND QUESTION
Discussion in 'The Garage' started by MJB774X, Apr 21, 2003.
  1. MJB774X
    MJB774X 1/2 ton status
    Sep 26, 2002
    574
    SO CAL
    I recently set up my own ring and pinion, I'm pretty confident that I set it up correctly, yesterday I drove my blazer for the first time with the set up, I drove it around for about an hour, when I got home I felt the case and it was prtty hot, when I set up my gears I did run a pattern to get the depth right, in fact it took several trys, I set the backlash to 9 thou., this was as close as I could get it to 8, so whats up with the heat? is it becuase the gears need to get broken in? I was thinking that maybe I set the nuts that you adjust the backlash with to tight, thus "squezing" against the carrier bearings, any thoughts, I cranked kind hard on those nuts does anyone have suggestions to setting those things, how tight?
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> It's damn near impossible to get the carrier bearing preload adjusters too tight, Randy's says to make them as tight as possible with a 10" spanner, and also says that he has never seen a failure due to too much preload on them.
    How hot is hot? Could you leave your hand on the case? I've hear (not an expert here) that so long as you can leave your hand on indefinately then it's OK. If you're worried then open it up and make sure that the gears aren't discolored from heat. </font>
  3. MJB774X
    Sep 26, 2002
    574
    SO CAL
    yeh you can leave your hand on it, but it is pretty damn hot, I'll run it for a while longer, and then pop the cover off and check it out, I was just wondering if anyone else had experienced this, I was also thinking once the gears develope a wear pattern the heat will go away.
  4. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    What kind of gears did you put in it?
  5. MJB774X
    Sep 26, 2002
    574
    SO CAL
    precision gear, 4:56's
  6. Shagnaz
    Shagnaz 1/2 ton status
    Jul 19, 2002
    308
    South Carolina, North Charleston
    I have the same gears and don't have the heat problem, but I have a problem with the pinion. I tighten it down and it loosens up. The nut isn't moving. I put locktight on it and marked it.
    Do you have to put alot of torque on that pinion nut?
    Mike B
  7. mastercraftkpk
    mastercraftkpk 1/2 ton status
    Mar 12, 2003
    192
    Houston, TX
    They will get very hot during the break in period. That is why it is recommended to break them in gently....maybe 5 miles then a cool down, then 30 miles then a cool down, then 60 miles then a cooldown, then CHANGE THE FLUID. If you are worried about the heat breaking down the lube, then change the fluid and you should be OK.
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif
  8. MJB774X
    Sep 26, 2002
    574
    SO CAL
    yesterday I drove it around somemore, when I felt for heat, the heat was concintrated on the pinion housing, as I posted a while back one of my buddys dads set up my rearend, he used no tools and did it all by guess and feel, when I checked the pattern it was way off, I took Shaggy's advice and re-did the setup myself, the one thing I did not do was take the pinion assembly apart, so I'm thinking my buddy's dad put to much preload? I don't know, I don't even know how your supposed to put the assembly together properly. do you guys think that the gears still need to be broken in? or is it possible the pinion assembly is to tight? when I did the set up I was able to spin the pinion with my hand, but maybe there is to much preload on the bearings? /forums/images/graemlins/1zhelp.gif
  9. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    It's just a case of "new Gear's and new bearing's" after the break in period, they should be just fine.
    After the break in period, I would suggest, changing the oil in the axle. /forums/images/graemlins/grin.gif
  10. MJB774X
    Sep 26, 2002
    574
    SO CAL
    I remembered when my buddys dad put the pinion assembly together, he used the old crush sleeve and tighten down the nut with an impact, then he backed it off and tightened it down more, he did this several times, today I called tri-county gear, I told him how the pinion housing part was getting real hot the first thing he said was too much pinion preload, he then told me that you only tighten the nut to 17 inch pounds of torque, my $hit was tighten by a freakin impact gun /forums/images/graemlins/angryfire.gif
  11. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Torqued with an impact wrench ehhhh? Not Good /forums/images/graemlins/smirk.gif
  12. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Hmmm, this is the SECOND episode in the last few months of someone's freind's dad messing up their gear install. The moral of the story? Don't let your freind's Dad set up your gears, and if you do, at least research it first so you know what should be going on with it. Hopefully the gears aren't ruined.</font>
  13. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> I was thinking about this post last night for some reason, and it occured to me that you might have misunderstood the guy when he said that you want the nut at 17 on/lbs. You don't actually want the nut torqued to 17 in/lbs, what you want is for the DRAG on the pinion assembly to be 17 in/lbs. That's how the bearing preload is measured, using a bar type in-l torque wrench to measure the resistance to turning the pinion. The nut itself will be torqued to close to 200 ft/lbs so long as the crush sleeve was not overcrushed. </font>
