Rearend upgrade
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by berg76, Jul 17, 2003.
  1. berg76
    berg76 1/2 ton status
    Nov 4, 2002
    238
    St. Louis, Missouri
    My buddy has a '98 4x2 chevy pickup. He is looking into possibly upgrading the rear axle to a 14bff or a sf. Can the fronts be changed to 6 or 8lug easily? /forums/images/graemlins/thinking.gif or would he have to go with a converter spacer ring thingamabob?
    I realize this forum is for 91 and older but I think there is much more knowledge floating around here than elswhere. /forums/images/graemlins/cool.gif
  2. berg76
    Nov 4, 2002
    238
    St. Louis, Missouri
    Turns out there is a 88-newer forum... doh /forums/images/graemlins/grin.gif
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    im curious on the newer trucks, can you swap hubs on them from 8 to 6 ?
    are the CV shafts all the same length and splines and such ? it is IFS CV shaft type front, right ?
  4. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    The C1500 can be changed into a 6-lug C2500 by simply changing the front rotors and the rear end. That gets you into the stronger 14SF (9.5") /forums/images/graemlins/thumb.gif
    8-lug is more involved. The frames are built differently to hold the beefier suspension. You'd be looking at a complete frame swap to do it right.
