rearend vibration
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by RAY, Nov 7, 2000.
  1. RAY
    RAY 1/2 ton status Premium Member
    Jul 4, 2000
    281
    Austin, Texas
    I have a vibration, more like a shimmy, coming from the rear of my K5. I have replaced the u-joints and the the shimmy didn't go away. I have a 15-yr old 3 in lift on it and was wondering if shims would fix this. Any suggestion would be greatly apprecated.
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    Have you checked to make sure your u-bolts were all tight and that your wheels/tires are in balance? Also is your driveshaft dented?
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; http://emmett.coloradok5.com
  3. Wheels
    Wheels 1/2 ton status
    Aug 18, 2000
    638
    Try the "rotate one of you u-joints 180 degrees in the yoke" trick and see if it works. I have a small vibration in mine and that the only thing I havent tried yet to see if it will quite.
  4. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Ok, so I keep reading and hearing about marking the driveshaft so that it goes back in exactly as it came out. What is this for? And what happens if you dont? I can see that it would really make all that much difference, but this could be the reason for some of my clunking.
    Don't you buy no ugly truck!
  5. JimmyDie6.2
    JimmyDie6.2 1/2 ton status
    Jun 20, 2000
    453
    Long Island
    wheel bearings could be a possibility also, as gor the u-joint, there is a slim chance that it could be defective........js
  6. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    When someone originally built your shifeshaft, they balanced it and added weight as neccessary so it's good and balanced.
    When you change ujoints, if you don't put it back in exactly the same you have changed the balance of it - for the worse.
    I just grab one of my daughter's pieces of chalk and mark it - a no-brainer. No vibes.
    BTW, if your driveshaft spline are very worn, it is impossible to balance it - it must be replaced. I'm going through that with my front driveshaft right now.
    Good luck on the vibes.
    -- Mike
  7. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    If I'm thinking of "shimmy" the same way you are, you could have a slightly bent axleshaft.
    [​IMG] Semper Maintenance!
