rearend whine
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by lugnut, May 29, 2002.
  1. lugnut
    lugnut 1/2 ton status
    Aug 3, 2001
    268
    North Carolina
    I have a whine under light aceloration I'm thinking its the rearend. Coasting it doesnt do it and seems like its not as bad if you realy get on it or maybe the pipes drown it out. I think the rear is a dana 70 its in a 85 duelly. I have checked the u joints and center suport bearing. Anyone got any ideas pinun bearing maybe?
  2. Mreetz
    Mreetz 1/2 ton status
    Jun 26, 2001
    1,282
    Subs of Denver, Colorado
    Somebody told me once to be careful replacing that seal back there. If you tighten it down incorrectly that can happen.
  3. Dunc03
    Dunc03 1/2 ton status
    May 20, 2001
    157
    Tyler,Texas
    A mechanic told me that normally axle bearing howl or whine when they are going out so you might check that out. It alot cheaper than a rearend I just had my 10 bolt rebuilt with a posi unit and it cost me about 1700. I had slackbetween the ring and pinion due to hard shifts and it made chirping noises going around short fast turns, like turning into some place from the middle lane. I would check out the axle bearing first. I ahd someone on hear tell me that you can do this by jacking up the rearend and putting the the tranny in drive with the engine at idle. If the either of the back wheels wobble in our out then check the bearing on that side. YOu might get a better response to this if you asked about the rear axcle bearing directly. hope that helps some.
  4. lugnut
    Aug 3, 2001
    268
    North Carolina
    Thanks its a full floater so the axle dosnt ride on a bearing. Should have said it was a full floater before. Probly be next week before I get a chance to pull the cover on it.
  5. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Thats what mine did too. sounds like bad carrier or pinion bearings
