Reason for exhaust to smell funny?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by UseYourBlinker, Jun 27, 2001.
  1. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    For the last 2 weeks my exhaust has smelled really bad,and not normal. It almost get's me sick when I get a whif of it. Everything seems to be fine (Plugs,wires,and gas mileage) so what gives? anybody have this problem before? It's a crate 350 from the dealer and it has about 50,000 miles on it..
    <A target="_blank" HREF=http://community.webshots.com/user/vwryda>http://community.webshots.com/user/vwryda</A>
  2. Wheels
    Wheels 1/2 ton status
    Aug 18, 2000
    638
    Cat convertor burnt out??? Does it smell like rotten eggs?
  3. UseYourBlinker
    Jun 7, 2000
    11,117
    Kind of...The cat and the rest of the exhaust system is about 3 years old.
  4. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    It's probably your cat... they smell bad sometimes... it's a nasty smell too! [​IMG] Buy some deodorizer and run it and it might help it...
    I removed my quote so gay, vegetarian, minority, eco-nazis who love Jesus, nuke spotted owls, vote Gore and smoke medical marijuana won't be offend.
  5. UseYourBlinker
    Jun 7, 2000
    11,117
    Will do..
  6. Wheels
    Aug 18, 2000
    638
    Come on Steph, put it back. It was your signature trademark. Besides, I have a ton of recipes for spotted owls.
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Lose the cat completely and it'll smell kinda sweet if it's tuned right.
    Tim
  8. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    You can't lose a cat in CA. Smog stations don't like it........LOL
  9. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Been getting gas at a different place than normal? The last time I got gas at Arco my exhaust smelled like lawn fertilizer until it was completely burned out.
    If it weren't for bad luck, I'd have no luck at all[​IMG]
    <A target="_blank" HREF=http://pugsley.alloffroad.com>http://pugsley.alloffroad.com</A>
  10. WOODYJ
    WOODYJ 1/2 ton status
    May 5, 2000
    144
    I will second, third and fourth the cat being bad. The way they have been screwing with the gas lately, who knows what you might be getting!!
    k5woody I Don't Understand The Jeep Thing Either!!!
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    If I had to have a cat I'd sell my truck.
    But you can use the Vortec style cat instead when you replace it, they're nice and don't make the exhaust any quieter, unlike other, bead type, restrictive cats.
    Tim
  12. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    Ya I'm on the bandwagon for the Cat being finished. Are you losing any power? Engine running at all different?
    Ratch
    **<A target="_blank" HREF=http://k5.8m.com>http://k5.8m.com</A> What more is there to life?**
  13. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    i've got a similar question on my non chevy. My exhaust smells like raw fuel. Recently gave it new plugs, wires, cap/rotor, but it still smells that way. Power is normal, mileage may be down slightly. It's a '96 F150 with a fuel injected 300 6 cyl. What could it be?
    Sherman, Tx
    <font color=red>Come Awn yall...Let's go to LUCHENBACH, TEXAS!!!
    </font color=red>
  14. newyorkin
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    if you have a raw fuel smell, then one (or more) cylinder(s) is not firing or not burning completely. Fuel goes in, compresses, expands, goes out. No ignition or not complete before being sent out the exhaust pipe.
    Stretch a rag over you exhaust pipe and run it for a few minutes. Then light the rag (in an open field or somewhere it will be safe if it blows up). If it ignites easy, then you definately have fuel passing the cylinders without burning. Older enignes this is more common, newer engines (96), this shouldn't be, even with EGR closed.
    I've seen cars with one plug wire off the plug that run smooth until you gas it. Maybe there's a loose wire? broken wire? To check that, start the engine at night, kill your under-hood light and look for sparks anywhere of any size. If you dont' see any, you should be good on obvious shorts (some guys mist water around to see if there's more spark).
    Check your spark plug gap, plugs for fouling, etc.
    Even if your timing was way retarded, it should still not leave much fuel in the exhaust.
    Good luck!
    Ratch
  15. UseYourBlinker
    Jun 7, 2000
    11,117
    I'm gonna take the Blaze over to the exhaust shop later today,and they are gonna check out the cat...The motor has run a little different than normal ever since the smell started. I use the same gas at the same Cheveron station that I always use.. The plugs,wires,and cap are recently been replaced. Everything looks good...
  16. walt88
    walt88 1/2 ton status
    May 24, 2000
    430
    Monmouth County, NJ
    Someone Help me! My exhaust stinks too. ITs a walker highflow cat with only about 6,000 on it. It smells like low tide. I don't get a SES light. All my sensors are good. I have tried blowing it out to. Rev up to like 5 grand.
    1988 K5- Piss on Ford/Dodge/Jeep
