REBEL PLUG
Discussion in '1982-Present GM Diesel' started by JORGE, Mar 31, 2001.
  1. JORGE
    JORGE 1/2 ton status
    Jan 10, 2001
    213
    VITORIA-GAZTEIZ(ALAVA)BASQUE COUNTRY,SPAIN
    Hello friends!
    Today i,ve been trying to extract the glow plugs.I only have extracted 7 plugs.The eighth cilinder plug(last to the left side)doesn,t wants to come out.It turns well to the end of the screw,but then it starts to turns crazy and doesn,t come out.It is swollen.
    How can i extract it with out raise the head?Thanks.
  2. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    You need to apply pull to the glowplug while unscrewing it. I've done it using a pair of vise grips and a wrench, but a better way is to make a fork like tool to pry on it as you turn it (with a wrench). Make a foot out of heavy guage sheet steel about 2cm x 4cm, cut a notch in one end use an old glowplug as a guide, weld a handle on the opposite end of the foot at a 60+/- degree angle. It's worth the time to make the tool.
    Now, worst case scenario: the glow plug tip broke off in the head (prechamber). Pull the injector out and use some hemostats (medical pliers) to grab or a nylon zip-tie to lasso the end of the broken tip. Don't leave broken bits in the engine, bad things will happen.
  3. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    I've succesfully used a vacuum cleaner to remove broken glow plug parts through the injector holes. Just duct tape a hose to the end of the vacuum hose that fits in the hole. Works great.
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  4. JORGE
    Jan 10, 2001
    213
    Yes is agood idea,but today i,ve solved the trouble with a nut ring and little lever help.I ,ve taken a ring with a hole,in the same measure than the plug neck,i,ve cut a part of it and put it around the plug neck.I ,ve pulled it while i unscrew it with a wrench.It has came out soon.
    Thanks for all the ideas.Jorge.
