Rebuild 10 Bolt
Discussion in 'The Garage' started by K5HIGH, Oct 10, 2005.
  1. K5HIGH
    K5HIGH 1/2 ton status
    Dec 8, 2004
    102
    harrison twp. mi.
    WHAT would i need to convert a 28 spline to a 30 spline?? reason im asking is ihave a 10 bolt that blew the ring and pinion and spider gear but can only find 30 spline parts. thanks
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    the only difference is the side gears where the axle goes in them, AFAIK
  3. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    If you have a 30 Spine diff. then you just need 30 spline axles. Done expect much more strength though...
  4. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    yeah, if you don't have a 60, you don't have sh!t :rolleyes:
    yeah all you need for a 28 to 30 spline convert is the side spider gears and the new 30 spline axleshafts.
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    The hole is slightly bigger IIRC , where the side gears are . Pinion shaft the same , spiders the same , ring gears will interchange .
    I own one of each spline front , 30 spline DD , 28 spline trail rig .
    I actually know someone who replaced a 28 spline govloc , with a 30 spline open , and reused the old ring gear ....... wait it was you :wink1:
  6. 4xcrazy
    Oct 31, 2003
    9,472
    5
    NOW,,,WHO, would do something like that !!! :doah:
    :D
  7. K5HIGH
    Dec 8, 2004
    102
    harrison twp. mi.
    so i have access to a the carrier with the ring in pinion and the spider gears and the axles all 30 spline. the reason i might go this way if it is feasable is i cant find a complete 10 bolt and dont want to upgrade to a 12 bolt because im proably selling it when it gets fixed. thanks so is there anything i need to get besides these parts?
  8. 4xcrazy
    Oct 31, 2003
    9,472
    5
    going 12 bolt is not really an upgrade though, the upgrade on here anyways, is slappin in a Dana 60 under the front if thats what your replacing, or a 14bff for the rear. :doah:
    the 12 bolt is almost the same as the 10, just a few minor differences.
