rebuild a dizzy or by a new one
Discussion in 'The Garage' started by adamforsythe, Aug 7, 2005.
  1. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    Hello,
    Well I was out reving my truck up showing it off and the main part of my accel super coil dizzy crapped out on me. Should I spend the money to rebuild it or just by a new one. There is a green wire that has a hole in it and it kinda looks like something blew up in the wire.
    Other than that wire the dizzy looks bran new.
    The green wire goes to the Module from the part that turns is the wire that crapped the bed.
    Adam
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Unless your bushings are worn out in the dist just buy new pick up coil and module and replace them.
  3. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    Hello,
    How would I tell if the bushing are gone? When I turn the dizzy it fells firm.
    adam
  4. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    If you can get more than about .015 side to side movement from the distributor shaft inside the housing then it's a little worn, but I have run worn bushings in a distributor for a long time and as long as you don't mind a little backfire on decel then don't sweat it alot, but since your in the mood for replacing stuff, just buy a rebuilt distributor and call it good.
