Rebuild axle price
Discussion in 'The Garage' started by bigcat44, Mar 1, 2005.
  1. bigcat44
    bigcat44 Registered Member
    Jan 29, 2005
    59
    Albuquerque
    Just spoke to Desert Rat today (we have one locally) and to rebuild my stock 10blt 3.73 axles I am looking at just under 1700.00. Included in this are re-gearing to 4.10s both frt and rear, new carrier for the rear, Detroit full locker in the rear, along with everything and labor oh and tax. Does this pricing sound reasonable? I am finding lots of axles here in the FS section that are a lot cheaper but I am not close to any of them! Any recommendations?
  2. dyeager535
    26,980
    Doesn't sound too outrageous to me. Labor is typically hundreds of dollar per axle alone, so two axles, plus all the parts, probably not outrageous.
    Now, since $1700 would buy a new crate motor, *I* think that's outrageous. :)
    I would suspect a swap to 3/4 ton gear could be done a LOT cheaper, and 4.10's should be much easier to find that way. I certainly wouldn't spend $1700 on a set of 10 bolts. They may work for you based on your usage, and nothing wrong with that, but for $1700 I might deal with the "hassle" of going with 8 lug wheels if that was your only hold up.
  3. xanthias
    xanthias 1/2 ton status
    Nov 18, 2004
    195
    Houston, Texas
    You could easily get 1-ton axles shipped to you by Forward Air or something similar for that kind of money.
  4. TB2Blazer
    TB2Blazer 1/2 ton status
    Apr 6, 2002
    166
    Cleveland, GA.
    Dana 60 and GM 14 Bolt FF.............ditch the ten bolts. If you have that kinda money and are wanting to get tires in the range of 35+ sometime in the future or plan to wheel it some what heavily then you would be much better off spending the money to upgrade the axles.
  5. bigcat44
    Jan 29, 2005
    59
    Albuquerque
  6. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    You would need to move the spring perches...pretty simple, and the shock mounts..pretty simple on the rear axle. You will also need a conversion u-joint ~$25. The front is a direct bolt in. 8 lug wheels and you are set:D
  7. bigcat44
    Jan 29, 2005
    59
    Albuquerque
    Hmmmm?? decisions decisions!!
  8. AkMudr
    AkMudr 1/2 ton status
    Dec 30, 2004
    917
    Alaska
    You can find a set of 1ton axles ready to run for less than 1700, you just hafta look. At the most you might hafta replace seals and brakes, big deal...the payoff is is so worth it!
  9. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I am not sure why you would need a new carrier for the rear axle, a Detroit locker is a full carrier locker that replaces the stock carrier or govlock carrier.
    If you want stronger axles then upgrade. If you don't need stronger axles then 1/2 tons and want a locker and some gears that sounds like a good price to me.
    Harley
  10. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    If I were you and wanted 10bolts. I'd buy these http://coloradok5.com/forums/showthread.php?t=129871 and make a road trip or have them shipped. Thats half price of what you were quoted and you'll still have your old ones for spare shafts and parts. Also, just from my experience you can find complete trucks with 3/4 or 1 ton axles for $1500 to $2500. Then you'll have extra everything....motor, tranny, tcase, driveshafts, sheet metal, interior. <--- I've always liked this option.
