Rebuild
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Adub, Jun 22, 2003.
  1. Adub
    Adub 1/2 ton status
    Aug 16, 2002
    106
    OK
    I freshened up the truck with a new top end a few thousand miles back. Now the #3 & #5 rings are starting to go and #8 isn't far behind. Me and a couple guys could easily do the rebuild. My block should still be good, but how much should I look at spending on parts, no labor? Probably keep the bore small, maybe .010 over. Nothing fancy, just quality parts? BTW, 89 TBI 350.
    AW
  2. Adub
    Adub 1/2 ton status
    Aug 16, 2002
    106
    OK
    And how much if I got a wild hair and decided to stroke it to a 383?
  3. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
  4. bigblock44k5
    bigblock44k5 1/2 ton status
    Jun 8, 2003
    396
    Hurlburt Field, FL
    cheack out PAW. they have ads in just about every vehicle realted magazine. You can get several different kits. One kit has bearings, rings, pistons, and a new cam for only $171, $335 if you want forged pistons. As for a 383, the only price I see without taking your searching job away from you, is for a forged crank that is the same stroke as a 400 but with 350 journals for $680. You could always get a stock 400 crank and have a machine shop grind down the journals to 350 size.
  5. Adub
    Adub 1/2 ton status
    Aug 16, 2002
    106
    OK
    Do the centerbolt engines require a different bottom end kit than the traditional engines?
  6. dyeager535
    26,980
    One piece rear main seal. Different crank and flywheel/flexplate for starters.
  7. midnight473
    midnight473 Registered Member
    Jun 4, 2003
    21
    Grayling, MI
    I thought the computer would compensate for the changes to a 383 making it not worth the change?? Was I told incorrect information?
  8. Adub
    Adub 1/2 ton status
    Aug 16, 2002
    106
    OK
    huh?
  9. blasterD
    blasterD 1/2 ton status
    May 24, 2003
    410
    Anchorage Alaska
    I think he meant that the computer would not tolerate the 383 without burning a new chip. If you dont mind getting a new chip then 383 would be a sweet setup.
  10. midnight473
    Jun 4, 2003
    21
    Grayling, MI
    Sorry, yes, that's what I meant. I was kinda tired when I wrote that. Reading it now I see where it made no sense.
