rebuildable 700r4 wanted!
Discussion in 'Parts & Trucks Wanted' started by outlaw612, Jan 16, 2003.
  1. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    I need a rebuildable core so i can have it rebuilt and ready to go when I pull mine out. Shipped to 62702.
  2. K5DRAGER
    K5DRAGER 1/2 ton status
    Jul 27, 2001
    1,164
    Momence, IL
    Let me check whats laying around.
  3. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    Matt,
    From what I hear you're wanting to TRY to find an '87 or newer core for rebuild. '87 and up have desirable changes.
    todd
  4. outlaw612
    Feb 11, 2001
    2,342
    How new can I go? (87-??)
  5. 95 Silverado
    95 Silverado 1/2 ton status
    Nov 9, 2001
    467
    Central PA
    they started using the 4L60E in '93, so you should be able to use anything from '92 or earlier.
  6. outlaw612
    Feb 11, 2001
    2,342
    So I need a 87-92. Thanks!
  7. sanford
    sanford Registered Member
    Dec 16, 2002
    42
    Plattsburgh NY
    I have an '89 blazer 700r4 4x4 tranny. It was a working trans when removed(about 3 months ago). what we thought was trans problem was actually broken flywheel.This trans has been completely torn down and cleaned. I have all the parts new to fix it(not torque converter)Can send you pics if you want. Let me know if your interested. I was thinking maybe $350.00 plus shipping.
  8. dawson444
    dawson444 1/2 ton status
    Jul 5, 2000
    1,034
    Raleigh, NC
    I have one out of my 88 in NC, i would say $150 plus shipping for it. Let me know.
  9. JRS2 75K5
    JRS2 75K5 Registered Member
    Dec 6, 2001
    40
    Central Missouri
    If you are still looking for one I have one that is suppose to have the right spline count on the front input to be the later model, more desirable one. It was runnig several years ago when pulled. $50 in Jefferson City Mo.
  10. outlaw612
    Feb 11, 2001
    2,342
    Do you know what year it is?
  11. outlaw612
    Feb 11, 2001
    2,342
    I just need a core, not a good trans. Thanks anyways.
  12. outlaw612
    Feb 11, 2001
    2,342
    Thats a little more than I wanted to spend on a core, thanks anyways.
  13. JRS2 75K5
    Dec 6, 2001
    40
    Central Missouri
    It was pulled from a 1984 sub diesel 4x4 but it was a replacement transmission. Local trans shop had me count the splines on the front input/pump and said it was the 85 or 86 and later model. The trans worked fine but leaked some out of the front around the converter. If you can use it let me know. Thanks.
  14. outlaw612
    Feb 11, 2001
    2,342
    Can you count the splines on the input shaft for me? Also, is there a K on the housing(on the top of the bellhousing).
    Thanks.
    Matt
  15. JRS2 75K5
    Dec 6, 2001
    40
    Central Missouri
    I will try to get a count of the splines either Sat or Sun and get back with you. I will also check on the "K".
  16. JRS2 75K5
    Dec 6, 2001
    40
    Central Missouri
    The spline count on the input shaft is 30. The large hub that the converter slides over, which is on the outside of the input shaft, has a coarse spline of 27. I could find no "K" on the bell housing of the tranny. There was a tag that indicated it had been rebuilt for General Motors by ??.
    Hope this helps some. Let me know. Thanks.
    Jim
  17. outlaw612
    Feb 11, 2001
    2,342
    Would it happen to be a K case?
  18. Marshall
    Marshall 1/2 ton status
    Apr 8, 2002
    204
    LiveRmore,CA
    I have a 700r4 K case, im still deciding if i should start a rebuild or sell it. You never know when one of these guys are gunna break.
  19. outlaw612
    Feb 11, 2001
    2,342
    How much? If its really cheap, I might get it for a spare but I have 1 being rebuilt right now.
  20. Marshall
    Apr 8, 2002
    204
    LiveRmore,CA
    I dunno.....i think i wanna try and rebuild it for the experience and the fact of having an extra transmission around cant hurt.I was thinkin maybe about $100 to make it worth my while.
