Rebuilding 1 tons?
Discussion in 'The Garage' started by PsychoticDeadGuy, Jul 16, 2005.
  1. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    I just picked up a D60 and 14bff axle housings...how much will it cost me to build these axles using the 35 spline axles and a spool in the rear. Could someone give me a price list for the parts needed and a list of stuff i should go back to the junk yard and look for. I am going out there in about 3 hours so help is needed asap. thanx
  2. BigCountryx
    BigCountryx 1/2 ton status
    Feb 19, 2005
    519
    Gonzales, LA
    All you've got are housings?............... Rob a Bank!!!!
  3. project84k5
    project84k5 Registered Member
    Sep 14, 2004
    40
    Fort Worth, Texas
    yikes :eek1: , i second that, i got complete axles and it still cost me about 6500 bucks to build both of mine (trashed), but thats with detroits, new gears, disk brake swap and so on and so forth, but i couldnt imagine even finding some of the parts for just the 60 housing alone :eek1:
    good luck, i will find my list of bearings and seals that i used on mine, and i think i might have some spare brake parts, calipers, rotors, etc... i think i might still have the factory 4.10 gears and front carrier, pm me if you want those parts
    ryan
  4. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    If the 14B is just the housing, scrap it. There are tons of them around for next to nothing.
    The D60 - wow, I hope you have room on your credit card. If it's just a bare housing, it DOES have the bearing caps right?
