Rebuilding a 14FF
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MudbogAD, May 8, 2002.
  1. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    I'm finally getting my hands on a 14FF. It is out of an 80 3/4 ton work truck. I know it has 3.73's but I don't know the condition. I am planning on putting 5.13's in it and running 39.5" TSL's. I was wondering what else I need to replace to get it in top condition. I was thinking new bearings and races but what else. Thanks in advance!
  2. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    That's about it. How about a set of disc brakes to loose some unsprung weight?
  3. MudbogAD
    Jun 29, 2001
    672
    Where can I get some more info on a disc brake setup. I think I really want to do this. I just need more info on it. Thanks!
  4. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I got my backing plates from misfit for $50 delivered. I think there are some others here that also sell them for a good deal. Do a search, some people here have done a pretty good job of documenting the job and it doesnt look to bad. Getting ready to do mine.
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    misfit
    45acp
    DERBINATOR
    TSM
    ORU
    Those are the main one's I know of. Beware of the last two as they are very expensive. /forums/images/icons/tongue.gif
  6. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    but dont the last two sell the complete kit so you dont have to track down calipers and all that?
    Later
  7. thatK30guy
    Jan 12, 2001
    32,076
    55
    Yes, they do, but those calipers are very easily and readily available just about anywhere. It's the e-brake calipers that will be the most costly part in the kit.
    BTW, why pay for the calipers in the kit when they will mark up the price when you can get them at the parts store for around $20 apiece? /forums/images/icons/wink.gif
  8. Rebel88
    Sep 7, 2000
    1,855
    Richmond, VA
    good point...i didnt know you could get them that cheap
    Later
  9. 86K5TrailBlazer
    86K5TrailBlazer 1/2 ton status
    Apr 24, 2001
    436
    Orange,CA
    anyone have a source for NEW calipers with compatible ebrake.
  10. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    you know what adam, you should give that 14bff to me/forums/images/icons/smile.gif j/k the engine is more than enough.
  11. MudbogAD
    Jun 29, 2001
    672
    Thanks for the replys guys. What exactly do you need to convert your 14FF to disc brakes. I know you need calipers and backing plates but what else? Thanks!
  12. Blazer79
    1,816
    1) Get the backing plates from any of the places mentioned above.
    2) Get 8-lug D44 (3/4 ton) rotors
    3) Get Cadillac Eldorado 1977 calipers if you want e-brake (expensive) or front D44 calipers if you don't want an e-brake (cheap)
    4) Get a pair of brake hoses and flare your alxe brake tubing. This is so you can remove the calipers and not pinch a line.
    5) Install, bleed and enjoy
    If I'm missing something, I'm sure someone will post.
  13. Blazer79
    1,816
  14. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    Are any of you guys using a proportioning valve? Or have you changed anything as far as the master cylinder area
  15. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Do you have a picture of misfits backing plates, and cane you use the caddy callipers on them?
  16. ramjet gmc
    ramjet gmc CK5 Staff Staff Member Moderator GMOTM Winner
    Dec 19, 2001
    3,370
    Milltown NJ 08850 NJ sucks
  17. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    a new cover, MOO makes a nice one, and thier truss...
    just some ideas. wire wheel it and paint it....
    umm, lock it. and i agree on the brakes.
    i did it. need to install the axle now.
    grant
  18. BozoWise
    Mar 28, 2002
    1,224
    Lubbock, TX
    How hard hard is it to do a brake job on the 14 ff I have never done a drum brake job. Is there any info out there on this.
  19. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    It's just like doing a front axle disc rotor swap, only you need a different socket. You've got to take the bearing part apart to get the drums off.
  20. MudbogAD
    Jun 29, 2001
    672
    Thanks again for the help! So I won't have any machining to do? The D44 rotors will fit? This sounds very simple. This is my next project so I am getting ready. Thanks alot!!/forums/images/icons/smile.gif
